raz0r$harP.UK Posted November 8, 2005 Share Posted November 8, 2005 UPDATED 1 JUNE 2007. STAY TUNED FOR SOME MORE ADDITIONS! Headunit Installation Virtually identical for all but here's discussion for R32 R33 - with links to pics R34 - courtesy of r34gtt.net Stagea Wiring up your headunit Nissan Wiring Harness information - verified as correct by me Need a DIN pocket? Just head to your local Nissan dealer. Any post-1996 Nissan car (eg N15 Pulsar) will have a DIN pocket that will fit in your Skyline. Antennas Jap - Aussie antenna conversion - you need an adaptor. The Aerpro AP348 is $15 from any stockist (Autobarn, etc) Can't pick up radio on a Japanese headunit? If your headunit reads on the Japanese FM frequency (~75-90kHz), you'll need a frequency/band expander to compensate. Pick one up from your local car audio store - the Aerpro AP745 costs $19. That, or get a new headunit Sound Deadening It's one of the most effective ways to improve the sound in your Skyline! If you're outside your car, knock the body panels and listen for that hollow 'tin can' reverberation. I'd go so far to say that deadening at least part of your front doors is mandatory if you are concerned about decent sound. Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/ Share on other sites More sharing options...
raz0r$harP.UK Posted June 1, 2007 Author Share Posted June 1, 2007 Speakers The factory speaker sizes were as follows: R32 - 4x6" front, 6.5" rear (Plate in front doors will see a 6" in there) R33 - 6.5" front/rear - mounting depth is approximately 57mm (as measured by me!) R34 - 6.5" front/rear - deep speakers are not a problem. There are no constraints with mounting like the 33. 6x9s will fit in the back fairly easily, need a spacer. 6x9s will fit in the fronts not so easily (again you'll need a spacer), but still doable. Predator's spacer template for front R32 speakers Changing rear speakers in your Cefiro Changing rear speakers in your R32 (including parcel shelf removal) Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154957 Share on other sites More sharing options...
raz0r$harP.UK Posted June 1, 2007 Author Share Posted June 1, 2007 Subwoofers Wiring up your subwoofer There are plenty of ways to wire up a subwoofer, depending on how many subs and amps you have, their configuration, etc. Crutchfield has put together a fantastic guide which shows you how to wire up as many as four subwoofers to your car. Check it out at the following link: http://www.crutchfield.com/learningcenter/...ers_wiring.html Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154964 Share on other sites More sharing options...
raz0r$harP.UK Posted June 1, 2007 Author Share Posted June 1, 2007 Troubleshooting Help! I've installed my system and now I get a whining / hissing sound from my speakers! Wayne Harris has written a fantastic article which covers most types of noise, and contains step by step information on how to isolate the problem in your car. It is a MUST READ if you are trying to troubleshoot. Read the article here: http://www.termpro.com/articles/noise.html Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3154970 Share on other sites More sharing options...
raz0r$harP.UK Posted February 6, 2008 Author Share Posted February 6, 2008 Wiring Diagrams (care of Chris Rogers) Tacho addition: http://www.apexi-usa.com/pdfWiring/3.pdf (this is the current RSM diagram - gives speed ,tach,ign wiring off ECU) R32 - RB20 P23 diagram:N4a R32 GTR - RB26 P23 diagram N4B R33 - RB25 P23 Diagram N4C R34 - P23 also ------------------------------------- R32 stereo wiring http://www.installdr.com/Harnesses/Nissan-Wiring.pdf when following this diagram the black wire on your radio goes to frame! nowhere else. --------------------------------------------------------------- R33 stereo wiring - SEE R32 ------------------------------------ R34 Stereo Wiring http://www.installdr.com/Harnesses/Nissan-Wiring.pdf use the 2nd diagram. for R33 S2 - use 2nd diagram. ----------------------------------- V35/M35 base spec: http://www.installdr.com/Harnesses/Nissan-Wiring.pdf 2nd diagram. DO NOT attempt this on a BOSE VERSION! it has an ENTIRELY DIFFERENT SETUP and you WILL kill something. cars later than 05 are CANBUS so be VERY careful here. ------------------------------------ 34 GTR display info inc swapping to non GTR dash. Here's a good guide for transplanting the MFD into an ER34. http://flatout.main.jp/driving/parts/bnr34mfd Here's an excellent guide for transplanting the MFD into an R33 http://www.geocities.jp/yossyi_bcnr33_carbon/inpure/MFD.html An AV cord to output TV onto the MFD (Clarion part #:855-5430-00) http://pub.ne.jp/BNR34/?entry_id=89518 MFD pinouts http://f14.aaa.livedoor.jp/~lindwurm/bnr34/diy/mfd/mfd.htm ---------------------------------------------------- PIVOT START BUTTON http://www.pivotjp.com/download/download-e.html Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3629119 Share on other sites More sharing options...
turbo_brian Posted May 14, 2008 Share Posted May 14, 2008 R32 Owners: If your planning on installing Amps and Subs, something you seriously need to think about is the grounding system in your car. The standard grounding system in the R32 (I am using a GTR as my reference point) is adequite for a headunit, and for the standard Skyline electrical system, but if you add high powered audio amplifiers, D-class monoblocks, and other hardware, then the stock grounding from the battery will be insufficient to power your gear. The biggest give-away that you have a grounding problem is that horrible engine noise that you sometimes get through your speakers, this is caused by the Alternator powering your device instead of the power feed coming from the battery. Electrical Theory: Basically, Electrical current (against popular thought) actually pushes the electrons FROM the positive terminal or power feed TO the negative terminal or Grounding point. If the grounding point is not up to the demand, then the Positive feed can not push out as much amperage. If your system is a sh1t-hot system, but you have the stock 8-gauge grounding fromt he battery to chassis to engine block, and your running a 4-guage power feed from the positive terminal to your amp(s), then when the system gets cranking, the system will bottle-neck at the 8-guage battery - chassis ground, and start demanding power from somewhere else that can both feed and ground adequitely. Guess what, the only other powersource in the car that can possibly meet the demands of your high-end audio gear is your alternator, so the system starts feeding from power from the Alternator as well as the battery, and thus, you have engine noise. How to fix this problem: Head to the local Jaycar/JB Hi Fi, Dick Smith Electronics, Etc, and get yourself a car battery terminal that will fit your battery. Next, get yourself either 4-gauge, or even some 0-gauge wire, probably about 2 meters will be sufficient, and your set to start work. Basically, you need to remove the current grounding from the battery to chassis to engine block, and replace it exactly as it's installed currently, but with the thicker wire. Remeber, current needs a clean path, so have some sand paper on hand, and where the cable gets grounded to the chassis, clean the metalic area completely until it's beautiful and shiny, then strip back the cable sheith and bolt down the cable (I like to use some clear-coat once this is done, to provide a barrier against oxygen getting into the freshly sanded metal and attracting a rust-spot). The bitch is grounding to the engine block, but with some patience and time, you will be able to get under the throttle body and undo the current ground and replace. This will resolve 90% of engine noise from from an R32 GTR's audio setup, if you still have engine noise, you haven't grounded the amplifiers correctly, but that's for another How-to or informational thread. Thanks. B. Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3867910 Share on other sites More sharing options...
M'ck'y Posted June 12, 2008 Share Posted June 12, 2008 I know this is a very old thread, but i now have a skyline:) Links to http://www.r34gtt.net/ don't work, any ideas where i could find r34gtt manuals? Thanks Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3938191 Share on other sites More sharing options...
infamous_t Posted June 12, 2008 Share Posted June 12, 2008 Search teh bit torrents, always a few manuals around, or try www.sewell.net.nz MODS feel free to delete my post if you want to keep this thread clean Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3938314 Share on other sites More sharing options...
M'ck'y Posted June 23, 2008 Share Posted June 23, 2008 Thanks, I couldn't find anything. What i'm really after is tutorial on how to install an amp in the R34GTt Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-3965469 Share on other sites More sharing options...
BAJ Posted August 28, 2008 Share Posted August 28, 2008 what about a sub in R34? there is very little space available. I wonder if I could put atleast an 8" sub woofer !!! would any of you suggest the best 8" sub? Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4097761 Share on other sites More sharing options...
Moodles2 Posted January 23, 2009 Share Posted January 23, 2009 With R32's front speakers, will only 4x6" speakers go in there without modifications.. if so, do car audio companies make 4x6" speakers to suit? Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4385643 Share on other sites More sharing options...
Chris Rogers Posted January 26, 2009 Share Posted January 26, 2009 yes they do. jbl do them. best results are with 6" items though. Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4389401 Share on other sites More sharing options...
Stephan Posted April 4, 2009 Share Posted April 4, 2009 The Aerpro from any Autobarn is chinese made unit with very, very poor performance! So, if you don't wish to have lots of static on radio reception, buy this one: http://bandexpanders.comze.com/1_2_Products.html Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4517856 Share on other sites More sharing options...
jsh58home Posted May 14, 2009 Share Posted May 14, 2009 i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space? Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4595543 Share on other sites More sharing options...
AadeshDaiwik Posted June 22, 2009 Share Posted June 22, 2009 I'm not a paid trader so I got banned Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4673013 Share on other sites More sharing options...
Duncan Posted June 22, 2009 Share Posted June 22, 2009 gooooone! Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4673183 Share on other sites More sharing options...
SCHSLYF Posted October 14, 2009 Share Posted October 14, 2009 i'm sure you can fit an 8" in a good box in the trunk with no problem. i've got room for a box holding two 14"'s in mine and the amp as well--have you got some other mods taking up your trunk space? with ever increaseing range of flat subs you should be able to purchase a good sounding sub that wont take up much room. these go fairly well http://kicker.com/compvt_subboxes <--- you can get them pre boxed in 8" 10" and 12" or you can get the subs on there own in the same sizes as well as a 6.5 inch which would need a custom box, or you could mount it in the rear speaker slots. pioneers version also goes well. http://www.pioneer.com.au/en/Products/Car%...Subwoofers.aspx (scroll down they are there, however i couldnt be botehred to find pre boxed versions but they do exist) these are from a 8' to 12" only as far as i know. i beleive a few other brands have had a go, but these are the only 2 i have actually heard and seen playing. so if you like your boot space, these are the way to go. Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-4880065 Share on other sites More sharing options...
R34 -_- Posted May 17, 2010 Share Posted May 17, 2010 Thread from the dead. Regarding subs in an R34, yes there is HEAPS of room wtf are you guys on about lol. If you have a factory 17" mag instead of a space saver and your no longer using the plywood sheet there is a nice spot on the left hand side (the wider wheel sits up more creating a nice slot either side) that will fit a 12" sub in an average size sub box. (warning don't put a large box there as it may move in the way of the hinge locking the boot shut, but a normal size wont) Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5238263 Share on other sites More sharing options...
Carbon 34 Posted July 20, 2010 Share Posted July 20, 2010 (edited) 2009-2010 R35 GTR Alarm diagram MODEL YEAR(S) GT-R 2009 -2010 KEY T-HARNESS IMMOBILIZER N/A N/A NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 PART COLOR LOCATION 12 VOLT CONSTANT GRAY (+) 40 AMP @ BCM, (BLACK, 3-PIN PLUG), PIN 1, NOTE #2 STARTER BROWN (-) @ PUSH-BUTTON IGNITION Switch or BCM, (BLACK, 40-PIN PLUG), PIN 18, NOTE #2 STARTER 2 LT. BLUE (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 21, NOTE #2 IGNITION 1 RED (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 11, NOTE #2 IGNITION 2 YELLOW (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 16, NOTE #2 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 31, NOTE #2 ACCESSORY/HEATER BLOWER 2 ORANGE (+) Low Current @ BCM, (BLACK, 40-PIN PLUG), PIN 24, NOTE #2 KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, (WHITE, 10-PIN PLUG), PIN 8 POWER LOCK PINK (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 17, NOTE #2 POWER UNLOCK BROWN (-), TYPE B @ BCM, (GREEN, 40-PIN PLUG), PIN 20, NOTE #2 DOOR TRIGGER GRAY (-) @ BCM, (GREEN, 40-PIN PLUG), PIN 39, NOTE #2 DOMELIGHT SUPERVISION PURPLE (-) @ BCM, (WHITE, 16-PIN PLUG), PIN 16, NOTE #2 TRUNK RELEASE GREEN (-) @ BCM, (GRAY, 40-PIN PLUG), PIN 36, NOTE #2 SLIDING POWER DOOR N/A HORN WHITE (-) @ HORN Switch, (GRAY, 8-PIN PLUG), PIN 8 TACH LT. BLUE (AC) @ POWER STEERING CONTROL UNIT, (WHITE, 12-PIN PLUG), PIN 10, NOTE #3 WAIT TO START LIGHT N/A BRAKE PINK (+) @ BCM, (GREEN, 40-PIN PLUG), PIN 7, NOTE #2 FACTORY ALARM DISARM DISARMS from FACTORY REMOTE ONLY!! ANTI-THEFT NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1 EXTRA INFORMATION NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 or XK07 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located in the PASSENGER KICK PANEL. NOTE #3: the POWER STEERING CONTROL UNIT is located under the PASSENGER DASH, behind the GLOVE BOX. Edited July 20, 2010 by sapphiregraphics Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356276 Share on other sites More sharing options...
Chris Rogers Posted July 20, 2010 Share Posted July 20, 2010 yep that is the USDM one. ADM is ENTIRELY different. Link to comment https://www.sau.com.au/forums/topic/94069-car-audio/#findComment-5356368 Share on other sites More sharing options...
