  • 4 weeks later...
  • 4 months later...
  • 4 months later...
what does everyone think about those ebay DVD units.. i know they will defenitely not be the best but i know if I start spending money on a head unit, Im gonna start wanting to do speakers etcs
im just looking for something cheap, and the ebay dvd ones seem to suffice. especially with Australian maps etc.. for about $400 max..
i didnt really wanna start a thread on it.. but yeh
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6041976
  • 2 months later...
there not to bad, I bought one 2 years ago, and it lasted me about 8 months before the screen no longer folded in and out properly, it would fold out when i started the car, then fold itself back in, or it would get stuck, it ate one of my favourite CD's and it ended up out the window on the hume hwy.
you get what you pay for, i suggest saving your money, these days you can get something decent from a trusted brand, with a warranty for 700+ so I suggest saving your money, especially if you have a nice car for it to go in :)
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6183836
  • 2 months later...
FYI
Just a quick update ipad tablets fit in R34 dash's with mods but same basic dash shape and console area, only the bezel trim and ashtray area needs remolded
They can be perm mount or slide out depending on how custom you want !! Test fit in my car today , plenty of space
And no metal to hit if you slide out on drivers side of lower fash , passenger side has a bracket
so before anyone asks ues you can do it
Cheers
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6298785
  • 6 months later...
  • 1 month later...
FYI
Cheers
FYI
Ipad mini ( 1st gen)
Fits in the dash of a R34 without excess mods or cutting , photos coming of kit fitment in dash
Could fit in just about any newer Nissan
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6682148
  • 1 month later...
Carbon also sells plug in connectors for most Nissan's for the home enthusiast installer!!! You only need a car side plug and the radio side plug like the following:
APP0120.jpg + APP8ALP.jpg = an installed head unit on a R34 :D
Plugs are about $15 each free postage for SAU!!
Some cars need extra parts like antenna adapters for the early Nissans if you have the standard head unit still installed.
Give us a call if you need anything we can try to help out.
Daniel Gardener | Auto Electrical Surgeon
T: (02) 9831 3288 | M: 0411 101 737
E: [email protected] | W: www.carboncarsystems.com.au
Unit 21/47 Third Avenue, Blacktown NSW 2148
https://www.sau.com.au/forums/topic/94069-car-audio/page/2/#findComment-6737140
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
