Pal Posted November 8, 2005 Share Posted November 8, 2005 Howdy guys an girls First post here so hello to everyone Got a small question about my gtst and I am wondering if anyone could help me. I have a r33 with a small amunt of work daone to it including 10.5 psi SAFC2 3" xforce exhaust with split pulse dump pipe standard intercooler auto box The problem is that the car has stopped producing power at 215rwhp. even if boost is turned up, it wont make anymore power? I have been told that I should be up around 240rwhp. it had this power before the safc was tuned up by the great guys at Hyperdrive and the dump pipe installed. Any ideas would be greatly apreciated Link to comment https://www.sau.com.au/forums/topic/94101-stuck-on-hp/ Share on other sites More sharing options...
paulr33 Posted November 8, 2005 Share Posted November 8, 2005 240rwhp is approx 178rwkw so its making good power. how much power did u expect? aftermarket ecu is required to go futher. you could try dropping the exhaust on a dyno run to see if the power goes, could be exhaust restriciton but i dont think youll make much without aftermarket ecu Link to comment https://www.sau.com.au/forums/topic/94101-stuck-on-hp/#findComment-1699641 Share on other sites More sharing options...
r33_racer Posted November 8, 2005 Share Posted November 8, 2005 ya std intercooler would be much of a restriction if your turning up the boost to make more power? People generally always go bigger fmic as a basic upgrade..improve cooling and removes restrictions in the piping to and from tb. a/m ecu like powerfc! Link to comment https://www.sau.com.au/forums/topic/94101-stuck-on-hp/#findComment-1699801 Share on other sites More sharing options...
Pal Posted November 10, 2005 Author Share Posted November 10, 2005 thanks guys for the help as stated i am only making 215rwhp as for the aftermarket ecu, i have been told that you cannot put a power fc on a auto, not sure if anything else can go on. was thinking it was the intercooler but wanted second opinion Link to comment https://www.sau.com.au/forums/topic/94101-stuck-on-hp/#findComment-1704707 Share on other sites More sharing options...
Wazz Posted November 10, 2005 Share Posted November 10, 2005 i'd be putting a bigger intercooler in.. fmic kits are getting cheaper nowadays it would be well worth your doin and you will notice more top end on the street so yer stock intercoolers are that small it isnt funny.. Link to comment https://www.sau.com.au/forums/topic/94101-stuck-on-hp/#findComment-1704979 Share on other sites More sharing options...
