Just wonderin to those whom have changed their shocks. What band and model are you using? Coilovers? How's the feel of it? Cause i'm lookin into a set of konis or bilstein in the near future. Any reccomendations? Please don't tell me tein, cause ain't gonna afford it. The only problem with the bilstein is they are non adjustable and it's supposed to sit the same height as the normal shocks. I know koni adjustables are not really good as the really good ones where u can set rebound... but hey... it'll do for the occasional track. Oh yeah, it's for the r33. I realised a lot of r32's change them, not as much r33's
Did a search and came out with nothing conclusive. :D
https://www.sau.com.au/forums/topic/94107-shoxx/
im running d2 coilovers in an r33
cost me about 1.5k install by EVOR,
High and damper adjustable. i think im running 8kg and 6kg springs
Driving in them is abit bumpy, but u get uses to do it (even on soft its still bumpy).
Just went drifting on weekend on the track, and the coilovers holded up perfect, was very nice handleing etc
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699666
That's the thing, i know u can't get the best of both worlds unless u go active air sup... which costs a bomb, but i'm thinking a little comfort, and a little handling, someone in the grey area in the middle. coil overs are crazy man, they are rock hard, but i know they handle better. I ain't gonna track my car everyday... so yeah. Neo, the bilsteins u have are non adjustables right? If u get the wrong sping height for the shocks, they die pretty quick. So that's another issue. How much lower is ur car?
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699682
I recommend the Bilstein/Whiteline kit from Sydneykid. Why? Cos I got one.
They are height adjustable at the time of installation (just move the circlip), and your car does sit a fair bit lower than stock. If you want fulli sik low ride height then look elsewhere because your suspension won't have enough travel and it'll f**k the handling. You'll be driving on public road, and it's got bumps - no point if your car flings itself off into the scenery if you're committed to a corner and hit a bump.
Having had coilovers in the car I can say from experience that the Bilstein/Whiteline kit is a great compromise. And no I don't sell them.
Check out page 2 of the R34 thread, I wrote heaps in there about my experience plus there's a photo to prove your car won't look like a 4x4 at the standard height of the Bilsteins.
http://www.skylinesaustralia.com/forums/in...opic=88141&st=0
Cheers! :D
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699712
I'm not lookin for anything low man. I'm already having trouble with the lowering springs which is the legal height. I'm happy with my height, i just want something that's good for normal driving, and some spirited driving. I like bilsteins, they make good shocks, but i was under the impresson they were non adjustables. Not height settings, but the bound settings.
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699768
To be honest I think having rebound adjustment is not really that necessary for normal use. My HKS coilovers had that and I played around with it for a week then never touched it. :)
It's just my opinion and I'm not some experienced race driver or anything but a well-sorted suspension setup doesn't need it, and simply adjusting rebound damping won't make an earth-shattering improvement if it's set up right in the first place. Even on the OEM market there seem to be very few active or adjustable setups that do anything useful - once you've got the balance set up how you like it, that's it...
But if you want it there are some options around supposedly designed for local conditions but yeah, I don't think they're cheap... :)
Hope that helps! Cheers
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699940
    • Here is as close as we got to a direct comparison(3 vs 4inch exhaust), a tickle more boost, which I am sure was in part due to the exhaust.  Made 790 on more boost.
    • Next minute, carbon fibre boot 😂
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
