Just wonderin to those whom have changed their shocks. What band and model are you using? Coilovers? How's the feel of it? Cause i'm lookin into a set of konis or bilstein in the near future. Any reccomendations? Please don't tell me tein, cause ain't gonna afford it. The only problem with the bilstein is they are non adjustable and it's supposed to sit the same height as the normal shocks. I know koni adjustables are not really good as the really good ones where u can set rebound... but hey... it'll do for the occasional track. Oh yeah, it's for the r33. I realised a lot of r32's change them, not as much r33's
Did a search and came out with nothing conclusive. :D
https://www.sau.com.au/forums/topic/94107-shoxx/
im running d2 coilovers in an r33
cost me about 1.5k install by EVOR,
High and damper adjustable. i think im running 8kg and 6kg springs
Driving in them is abit bumpy, but u get uses to do it (even on soft its still bumpy).
Just went drifting on weekend on the track, and the coilovers holded up perfect, was very nice handleing etc
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699666
That's the thing, i know u can't get the best of both worlds unless u go active air sup... which costs a bomb, but i'm thinking a little comfort, and a little handling, someone in the grey area in the middle. coil overs are crazy man, they are rock hard, but i know they handle better. I ain't gonna track my car everyday... so yeah. Neo, the bilsteins u have are non adjustables right? If u get the wrong sping height for the shocks, they die pretty quick. So that's another issue. How much lower is ur car?
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699682
I recommend the Bilstein/Whiteline kit from Sydneykid. Why? Cos I got one.
They are height adjustable at the time of installation (just move the circlip), and your car does sit a fair bit lower than stock. If you want fulli sik low ride height then look elsewhere because your suspension won't have enough travel and it'll f**k the handling. You'll be driving on public road, and it's got bumps - no point if your car flings itself off into the scenery if you're committed to a corner and hit a bump.
Having had coilovers in the car I can say from experience that the Bilstein/Whiteline kit is a great compromise. And no I don't sell them.
Check out page 2 of the R34 thread, I wrote heaps in there about my experience plus there's a photo to prove your car won't look like a 4x4 at the standard height of the Bilsteins.
http://www.skylinesaustralia.com/forums/in...opic=88141&st=0
Cheers! :D
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699712
I'm not lookin for anything low man. I'm already having trouble with the lowering springs which is the legal height. I'm happy with my height, i just want something that's good for normal driving, and some spirited driving. I like bilsteins, they make good shocks, but i was under the impresson they were non adjustables. Not height settings, but the bound settings.
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699768
To be honest I think having rebound adjustment is not really that necessary for normal use. My HKS coilovers had that and I played around with it for a week then never touched it. :)
It's just my opinion and I'm not some experienced race driver or anything but a well-sorted suspension setup doesn't need it, and simply adjusting rebound damping won't make an earth-shattering improvement if it's set up right in the first place. Even on the OEM market there seem to be very few active or adjustable setups that do anything useful - once you've got the balance set up how you like it, that's it...
But if you want it there are some options around supposedly designed for local conditions but yeah, I don't think they're cheap... :)
Hope that helps! Cheers
https://www.sau.com.au/forums/topic/94107-shoxx/#findComment-1699940
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
