Regency is the suburb that the motor vehicle testing place is. If you bring an import or a car from another state into SA and want it to be registered in SA than you have to take it to the workshops in regency for a compliance inspection. Remeber that they don't transfer your remainibng rego from state to state so if you have moved here don't bother changing to SA rego untill your old rego is about to run out. Hope that answers your question steve.
Steve,
I'm sorry to say but it sure will :)
"Regency" is the term commonly used for the Regency Park (suburb) Vehicle Inspection Station. It's the place to get defects cleared, import compliance checks, & most important to you, rego transfers (WA to SA).
I had to go through a basic Vehicle Identification Inspection (VII)when I transferred from NSW to SA. You can only remain on WA rego for a small time period (can't remember how long?). My NSW rego was due & I could've just renewed it but as NSW requires a road worthy inspection anyway I needed Transport SA to sign off on it!
I rang & asked Trans SA & they said I MUST transfer to SA, even though I'm in the Defence Force & "should" be able to remain registered in whatever state I choose! Anyway I bit the bullet & got it done ;)
You only need a VII not a full roadworthy (much bigger - nasty!) but they'll still pick you up for obvious no-no's. The purpose of the VII is to ensure the car is legally registered to you & complied within Australia. They check the VIN & Eng #'s (engine # is stamped on the block low down LHS).
As a rough guide here's what I did/didn't have a hassle with:
*Failed*
MOMO Race wheel - didn't comply with ADR's. It did! They were full of B/S but I wasn't going to fight it because......
That was all they picked me up on! :P:D:D
*Passed*
Lowered - didn't check
Exhaust - ditto (didn't look under the car @ all!)
K&N pod filter
A Pillar mounted boost gauge
Razo pedal set
Aftermarket ECU/turbo - ditto
& plenty of other little potential no-no's
Things I fitted straight after the inspection (I mean that day!) that would be a good idea to NOT have fitted for the inspection:
Oil catch can (regardless of set-up ie legal or not)
Aftermarket BOV
I wouldn't have dark tint either as they REALLY target cars with dark tinting!!! Dunno' why?
The inspection only takes 10-15mins max & any minor drama you can do & come back, same day (I fitted my stock s/wheel & passed a few hours later).
But........ I got my inspection done @ another station south of the City, can't remember the name of the place now, but can recall how to get there! I took it there as they only did VII's & therefore no waiting list, just rock up & in you go! They were less likely to go over the car with a fine tooth comb as well!
Hope this info is of some help mate.
Originally posted by whatsisname
*Failed*
Aftermarket BOV
DOH. Where abouts is this other inspection place - sounds like it might be worth a shot.
So your in the defence force - which one? I am one of those too, just got posted to Edinburgh, but I am a submariner (dont hold this against me...lol) - Now I'm postwhoring my own thread. hehehe
Thanks for your reply
Steve
Steve,
I'm an AVTECH in the RAAF (14yrs). I've been @ Aircraft Research & Development Unit (ARDU) for ~18mths, so pretty much Edinburgh too :) Currently the main ARDU area is 2mins drive from the base but our new facilities on the base are scheduled for completion late this yr.
I'm guessing we'll cross paths from time to time :P
As for the 2nd inspection station, I can't recall the name of the area? But I can find my way back there from memory, if need be mate ;)
Originally posted by hippy
how come the pillar mounted gauges pass?? i thought they were illegal??
I don't know what the legalities are with regards to additional gauges? But I have "heard" that clearance is the major issue. Clearance from potential head injury in an impact, & from obstruction of vision. My Autometer boost gauge neither blocks my vision nor poses a risk of impact in a crash.
I don't think the inspectors were that concerned with my gauge/A pillar mount, maybe they were in a good mood that day? It was a Friday.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
