Item: Garage Clean Out
Item Condition:Varing Conditions
Reason for Selling:Need more space and money
Price and Payment Conditions:Would prefer Perth buyers but will sell to anywhere
Hi all
I am having a garage clean out and I have several thing to sell:
- Blitz Blow Off Valve (possible a DD modle but not sure) $250
- std R34 (Rb25det NEO) Turbo with polished compressor housing (perfect cond) $700 (Great upgrade for R32s and R33s)
RB20DET Parts (R32)
- std turbo (good condition, never boosted, minimal shaftplay) $400
- std Flywheel (machined and balanced) + clutch (slips) $300
- cat back 3.5in exhaust (been modified to fit R32 4 door syline) $100
SR20DET Parts (S13 180sx)
- std T25 turbo (suits rebuild) $50
- std Exhaust manifold $50
- std Fuel pump $30
- std Injectors x4 $200
- std Airflow metre (with plug) $100
- std Front calipers x2 $150
- std Clutch pressure plate + clutch plate $80
- std Comp $200
- std Timing chain guides (both sides) with bolts (all perfect condition) $100
- Interior console cover (thing that clicks around radio and gear stick) $50
- Auto gearbox shifter (sports one, not standard, looks cool) $50
All prices are negotiable and pics can be provided apon request
Iam located in Perth and would prefer Perth buyers but will sell to anyone :) , but buyer will have to pay for postage :)
https://www.sau.com.au/forums/topic/94208-rb20det-sr20det-garage-clean-out/
hi in perth also, could i arrange viewing time for exhaust...and would like to noe wat has been modified.
also does it include muffler? wat style is the system.
thx
hi
Well the exhaust is 3.5 inch all the way through with a middle muffler and a end muffler. Looks very similar or even could be like a HKS or Turst exhaust. We got it from some jap wreckers saying it would fit an 32 but it didint so all we did was modify the length and the supports, thats all. It should fit a 2 door also but not sure. It bolts atraight on after the cat and looks and sounds good.
cheers
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
