I spoke to my mechanic about this and he is a good friend of mine since I've been going to him for close to 3 years and so has the rest of my family so I know that he isn't bullshiting me..
here is what he said..
The normal spark plugs that you can get from NGK or Champion with the normal copper tips will FLOW (if that's the word to use here) more electricity than the platinum and iridium ones.
He showed me some stats from tests that were done at some industry show that he attended.
The only good thing about the platinum or iridium plugs is that you don't need to change them for something like 50,000 kms or more.
The standard copper plugs are supposed to be good for 20,000kms.
And if you're car runs rich (lets face it, most skylines do) then you are going to have to change any plugs you have more frequently.
Don't know about you guys but I am not about to spend a shit load on spark plugs that are simply going to last Longer. I'd rather change them every 20,000kms and have brand new ones in there more frequently, that also FLOW better.
Also, he recommends that cleaning them to get more life out of them is a waste of time.
I still run NGK Copper plugs in my car with the standard 1.1mm gapping :)
Works fine. As GTST said, the NGK copper plugs actually do have a higher conductivity (if there is such a word) rate than the plats or iridium. Longevity is the benefit from not using coppers.
about $3-4 VS $18-$20
just go the coppers.
Also try doing a search as this has been posted many upon many of times...
the best copper plug i have tried so far is
NGK BCPR6E (WITHOUT the -11 on the end, meaning a 0.8 mm gap rather than 1.1) If you have boosted your car, the plugs will perform better longer at a gap of about 0.65 - 0.7.
im with zahos
i put coppers in last weekend NGK BCPR7E.11 though (i figured for $20 i would try) car rund fine, well better than it did on the old daggy platniums.
im not fussed about changing plugs more often if im getting a cleaner spark at a cheaper short term outlay.
next time i'll order in the colder heat range plugs
use copper plugs for sure, the others arent worth it because they will foul if your car runs rich and you just wasted a shit load of money.
and ALLLLWAYYYYSSS gap ur plugs before u install them, just because the packet says there gapped to 1.1 dosn't mean they are, gap em urself and u will see how off they are outa the pack.
Hey Pawley,
what kinda power figures you got? Reason I ask, is b/c if you go a colder heat range, the plugs will foul very quickly if your car is close to stock. I put a heat rating of 7 in mine (but I only had cat back and boost at the time), and with 2 weeks i had to change them.... (or clean em), so I went back to 6 which was a lot better for my car..
Zahos
  • 3 weeks later...
I just pulled mine out tonight and inspected and cleaned with some sandpaper and metho and seemed to look much cleaner. Not sure whether it will make a big difference but i haven't given it any stick on the road yet.
They were NGK-R code# BCPR6ES - looked pretty much copper to me. Today i did get some pricing on some platinum and irridium ones from Recpo - either $22 each for platinum or $28 for irridium (or was it vice versa?). When i heard that i just said thanx but no thanx. Now that i've checked them i should have just gone the coppers and installed when i had everything apart.
The thingo on the bottom of the bonnet says 1.1mm so that is how they must come out of the factory but anyway we'll ignore that.
Mine were gapped to 0.85 so just left 'em as is. Were fairly dark but i've seen worse. Interestingly noticed some whiteness on the plugs in cylinders #3 and #5 - would that indicate running to rich or lean? What is the firing order of the RB25DET ? I assume that has something to do with it.
Whiteness is very bad, it means you are running way too lean.
If you are not running with slightly dark plugs (a good indication that your engine is running rich enough) then this will cause some major internal damage if it's continued to be driven hard.
on the dyno day we had yesterday the mixtures were pretty sweet.. around 12.5:1
I think it could have been because the previous owner said he was having big troubles with the mixtures a while back. When he put the S-AFC in it fixed the problem.. So the plugs if they haven't been replaced since, the whiteness could be from then. I'm hoping that was the case anyway!
Anyway, i shouldn'a done half a job and just cleaned 'em -- i'm getting new ones.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
