Damaged by side collision on left B pillar.
SILVER IN COLOUR "Automatic"
Engine in good condition and has done 60 000 km
plus automatic gearbox - $3000
Bonnet - $200 (slight damage. LH Front)
Guards RH - $300
Radiator and Shroud - $350
Head Light RH - $300
AC Condensor + Bottle reciever - $300
Door complete - $600
Rear Quarter glass - $150
Seats Emaculate - $300
Door trims - $150
Billstien performence Suspension - $2500
Boot Lining complete - $200
Rear Seats - $200
Front Dash - $300
Speedo gages - $100
Rear Cut - $1000
Rear Light LH - $250
Rear Window - $400
Low arm Rear - $200
Tail Shaft - $200
Rear Diff 60 000 Km's - $1500
Petrol Tank - $200
contact peter on this site or phone on 0418570665
https://www.sau.com.au/forums/topic/9422-wrecking-96-skyline-r33-gtst/
