I've been on the phone to him most of the day for the door and front guard ....... I hope it's a 96 Series 2 as otherwise the door trim wont match :D
Isn't that a series 2 wing tho ? I thought the Series 2 had the M spec kit which inc that wing and the skirts ?? hmmmm.
