hey all i have just bought myself a skyline so i am a bit new to the workings of the car so i was wondering if u guys could shed some light...
1. my hicas light keeps coming on????
2. i fitted a turbo timer and it all works fine. but on my car the doors lock when you start driving and then when u turn the car off they unlock so when the turbotimer turns off the doos unlock??? know how to get around this??
3. whenever i shift gears mainly 1-2 and 3-4 at high revs it crunches gears... i know its not my driving, the clutch releases really close to the floor but it doesnt slip at all?? and the gearbox is tight and no rattles??? so i have no idea what the problem is maybee a bent clutch falk??
any feedback on any of these would be great thanks leigh.
https://www.sau.com.au/forums/topic/94243-whats-wrong-with-my-32/
hicas light = check your power steering fluid, crunching of the gears sounds like synchros mate, i had the same from 3-4 change, i had to get the box pulled apart, and it cost me a pretty penny, but thats mainly cos my box is the same outside size as a gtr box, so harder to pull out and in...good luck mate :)
1. [sEARCH] !!
2. Get rid of the timer. If you can control yourself for 1 minute before you are ready to stop, then you don't need the timer - it is quite safe to turn the engine off immediately.
3. Synchros. But, if the clutch engages quite close to the floor, then it might be time for a replacement clutch.
1. [sEARCH] !!
I would have to disagree with it being quite safe to turn the engine off immediately.
Yes...for the engine, but it will totally screw your turbo. That is why the timer was designed.
As for the clutch, take it to a mechanic to have it checked- -they don't have to know anything about imports to tell you what is wrong with it and there are so many possibilities that I do not care to go into depth about it - it iwould take all night.
Hicas light.....does it just come on and stay on all the time or only after a certain amount of driving. Do you have an aftermarket steering wheel? Does your speedo play up at all? Does the steering go extremely heavy, semi heavy or not change at all when the light comes on?
In regards to the timer, what sort of alarm system do you have? Its probably a program some called "anti-hijack". Find out what system first and take it to your nearest security installer and un-program it.
Cheers
My HICAS light basically stays on all the time now, but ive removed the hicas at the rear for a lock kit, my steerings all the same no lack of, although i understeer heaps (skyline trait) ive just moved on i think my hicas rear unit was screwed anyways.....all in all man, put alock bar on it and remove the hicas rear steering all together its better that way i can tell u the proper way to do it if u buy one without instructions.
3LIT3 FORS3 I would be interested to hear your reasons why not having a turbo timer will "totally screw your turbo"?
The turbo timer was conceived long before advances in turbo design and oil lubrication have made it an unnecessary waste of money.
It was developed to prevent cooking of the oil in the turbo oil lines which would cause blockages and starve the turbo of oil. New synthetic oil compounds and the removal of certain impurities prevent this from happening.
Doing 10 hot laps at the track and immediately shutting off the engine may have some effect, but the occasional romp at the track doesn't warrent wasting money on a turbo timer.
As for the crunching of gears. I'd say it was the syncros. This is common.
It has absolutely nothing to do with oil cooking in the lines and causing a blockage.
It is called coking. Coking happens when oil (of any type - no matter how good it is) is subject to high heat and high friction.
Turbos can sit comfortably at 700 degrees C and spin at speeds of an average 150,000 rpm.
The bearings spinning at 150,000rpm cause the oil to severely thin out and sometimes froth up. Your turbo is spinning this fast as soon as it hits full boost so it doesn't take any amount of track work to get it there. With this extremely thin, frothy oil covering your bearings, if you switch off the car immediately it does not give the turbo sufficient time to cool down to an adequate temperature. This added heat on the oil that is already very thin and frothy causes it to bake onto the bearings. Once you get a collection of this baked on crud it starts wearing the bearings away...just like having grit in them. Say bye bye turbo!
On the other hand you can do what experts advise and listen to people who have decades of experience in this area and install a turbo timer. This timer will keep your engine running at idle for a minute or so and, thereby, cool down the turbo. This also has the effect of fresh oil being flushed over the turbo bearings removing any thin frothy deposits that may be present. I CAN 100% GUARANTEE THAT A TURBO VEHICLE WITH A TIMER FITTED WILL HAVE IT'S TURBO OUTLAST ONE THAT DOESN'T.
FURTHER TO THAT, I ALSO 100% GUARANTEE THAT ANY VEHICLE FITTED WITH A TURBO TIMER, EVEN IF IT DOESN'T HAVE A TURBO, WILL OUTLAST A VEHICLE THAT HASN'T GOT ONE AND DRIVEN UNDER THE SAME CONDITIONS.
As for the synchros...you may be right, but he did mention that the clutch engages right on the floor which would indicate a problem with the hydraulic system or pressure plate.
common problem, usually caused by aftermarket steering wheel
some alarms do this, read turbotimer manual
Try changing gearbox oil, use Redline Lightweight Shockproof -- this "liquid gold" is known to fix many gearbox problems like you describe.
Cheers
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
