not a timing belt..... just having a stab in the dark here. or a really farked thrust bearing.
could be turbo even.. have ya chucked your head under th bonet to see if you can hear where it comes from
Thrust bearing?
It's an auto.
Does it make the sound while free revving (neutral) it or does it have to be under load? (driving down the street)
https://www.sau.com.au/forums/topic/94247-weird-noise/#findComment-1701612
YEAH AT FIRST I THOUGHT IT WAS SOMETHIN LIKE THE CAT BUT ITS BEEN CHECKED BY 2 DIFFERENT MECHANICS AND THEY RECKON THE EXHAUST IS FINE MAYBE THERE MISSED SOMETHIN WEN THE CAR IS WARMED UP ITS FINE SO WOT EVA IT IS PROBABLY EXPANDS OR SOMETHIN IN THE HEAT TO STOP IT BUT ITS WEIRD HOW IT ONLY DOES IT UNDERLOAD NOT WEN JUST FREE REVING IT
https://www.sau.com.au/forums/topic/94247-weird-noise/#findComment-1703600
Is there any way you could be a little more specific on the noise. 90% of the time when I am trying to sort out a problem for a customer they are saying 'bang' when really it's a 'click' or 'rattle' when it's a 'squeak'. Can you describe it any better than fluttering and have you gone for a drive with someone to try and locate the position of the noise a little better.
When they checked the exhaust, did they check your manifold gasket (often missed on an exhaust inspection).
Easiest way to test it is get a rag big enough to fold up and put over your exhaust tip. Then get someone to block the exhaust in 2 second intervals while you stay up the front and listen for any leaks. You will hear it start to hiss when your friend blocks the end as the pressure builds up quite quickly. This noise may be present while the engine is cold because everything hasn't expanded yet. Once the heat get's through it and the manifold expands a little, it will seal off the leak.
Go check it out - easy to do at home and will rule out the exhaust.
If it's the cat, all you gotta do is get half under the car and give it a bash, if it rattles - it's rooted. Only a rattling cat will make noises while driving.
https://www.sau.com.au/forums/topic/94247-weird-noise/#findComment-1703882
ILL GIVE THAT A TRY THE ACTUAL NOISE SOUNDS AS IFS ITS COMIN FROM THE MUFFLER BUT I HAD THAT CHANGED AND DIDNT STOP IT ITS KIND OF A RATTLE FLUTTER IF THAT MAKES SENSE ITS WEIRD HOW IT ONLY DOES IT AT A CERTAIN REV PROB BOUT 2800 AND PROB STOPS WEN I GO PAST 2900-3000
https://www.sau.com.au/forums/topic/94247-weird-noise/#findComment-1706140
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
