  • Replies 49
Hey mate,
I've sent u an email..
I'm after the Engine Wiring Loom, ECU & AFM..
Cheers..let me know
Interested in the whole boot interior, even the semi circle board that goes over the spare tyre.
is this still available and how much?
  • 4 weeks later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
