Bu5ter In The 10's!
The dampener won't make any difference. And blocking the detached hose with your finger is only about eliminating the vacuum leak which will cause the idle speed to increase (which you can hear happening when you block/unblock it). But the reg? It's not doing anything at all. Nada.
well....I'm no turbo selection expert so I'll leave that to others, looks like you've got what you need from a supporting mods side though including the twin scroll manifold; that means you really want a twin scroll turbo to not waste the advantage, it will make the same boost/power a couple of hundred rpm sooner than a single scroll turbo
Gotcha! Thank you for the correction. The goal would be 600 bald eagle (screech) pony power yielded on a roller dyno, but I’m more interested in responsiveness at low RPM and full-boost before 4000RPM.
93US is 98RON. 91 is a little on the low side to try to push to 600HP, but at least you can control boost to something more conservative when you're not on the good stuff. Also, we should check. Is that 600HP at the flywheel? Or using the usual pony power yielded by US roller dynos?
Hi! That is correct. 91 Octane US. probably similar to P98 AUS. I’ll update my location
