My 33 idles like a WRX but is perfectly fine once the revs are up.
It isnt plugs/ coils etc. Ive done a search but with no help.
What could be the problem?
Thanks in advance :)
Edit: It has hapened before but it just disapeared. I recently changed plenums back to a standard one and now its doing it again but with no sign of leaving.
Thanks again
Edited by 33SOM
https://www.sau.com.au/forums/topic/94280-another-idle-thread/
Forgot to mention Ive got a new Z32 AFM and a power fc :)
Its only hapened since the plenum change. With the old plenum it never used the aac/ air reg etc and idled good. Ive tried disconecting these with no change :)
vacume isnt leaking anywhere?
That is one thing Im thinking it could be. there sounds like air leaking just below the aac but from what I can see there isnt. I used new hoses aswell.
I unpluged a vaccum hose to see if the idle would change and it didnt. Does that mean anything??
might do.... not 100% sure but, my car had same symptoms with a vucome line off, id just check em all again to make sure. you can always spray some wd40 on any areas that look sus and see if it changes the idol, if it does you have found your leak.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
