My 33 idles like a WRX but is perfectly fine once the revs are up.
It isnt plugs/ coils etc. Ive done a search but with no help.
What could be the problem?
Thanks in advance :)
Edit: It has hapened before but it just disapeared. I recently changed plenums back to a standard one and now its doing it again but with no sign of leaving.
Thanks again
Edited by 33SOM
https://www.sau.com.au/forums/topic/94280-another-idle-thread/
Forgot to mention Ive got a new Z32 AFM and a power fc :)
Its only hapened since the plenum change. With the old plenum it never used the aac/ air reg etc and idled good. Ive tried disconecting these with no change :)
vacume isnt leaking anywhere?
That is one thing Im thinking it could be. there sounds like air leaking just below the aac but from what I can see there isnt. I used new hoses aswell.
I unpluged a vaccum hose to see if the idle would change and it didnt. Does that mean anything??
might do.... not 100% sure but, my car had same symptoms with a vucome line off, id just check em all again to make sure. you can always spray some wd40 on any areas that look sus and see if it changes the idol, if it does you have found your leak.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
