Hey,
I want to fit 20s on my R34 Skyline GT-T but am not to sure if they'll fit? The wheels I am looking at are 20 inch wheels with a width of 8.5". I want to put 225/35 tyres on the front and 245/35 tyres on the back. The available offsets for the wheels are +20 or 35. I also have coilovers on which may make things a bit tricky. I know that I am going to have to get the speedo recalabrated.
Can anyone help me out here? Would they fit on, or whats the modifications needed?
Thanks.
https://www.sau.com.au/forums/topic/94283-fitting-20s-on-a-r34/
Here's a pic of an R34 with 20s at the BAS. I remember sticking my fingers under the guard and could definately feel a bit of scrapage. Do not get the one with offset +20 as they are more GTR offsets and u will definately have issues with the wheel sticking out past the guards. It'll be a very tight fit and there is no sure way to find out but to do a test fit before u get it. Post some pics when u get it done :D
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
