Can anyone recommend a tyre shop to sell me a set of Street legal race tyres?
My V35 is being complied in Brisbane now so I thought fitting a set of these tyres would be better than a cheap compliance set that I'll never use. At least I'll then have a set of track tyres for later.
I'm in Perth so so local knowledge would be great if someone can help.
https://www.sau.com.au/forums/topic/94290-street-legal-race-tyres/
Hehe, this is the Queensland section, dude :(
The car is in Brisbane at the moment getting complied, but he lives in Perth :(
So he needs local Brisbane knowledge
Try Tyretech at Albion or there is another place accross the road from Suncorp staduim that does street and race cars. I think it is called Mark Williams Automotive?
What are you after? Like size, price etc.
As i have a contact here at work who'se husband runs his own small business and sells tyres at wolesale price. To give you an example, i got my Hankook K104 255x17x40 for $252 each
Give me a ring if you want 0403 477 372
Shane
Just got off the phone to Ian Boettcher Motors (3282 2722) (im after a set too) and they said youd be looking at roughly $500 a tyre.
Bridgestone RE070 he can do for $330
Top Yokohama for $540
Seeing as though your in Perth, i could arrange to get ur tyres to your compliance shop, if you want.
Also i'd give consideration to all the stuff that is happening on the docks as all the containers cannot be accessed so there may be a wait for your tyres.
Shane
what sorta size are you after?
There's a new chain of tyre shops opening up up here at the moment called "Tyres and More" that seem to do a bit of motorsport related tyres... Mind you, they were rather exxy (i think they wanted like $360/tyre for RE55's in 205/55/16)
how about semi-slick tyres as close to race tyres while still being legal
That is the sort of tyre I was hoping to get as long as it was DOT approved.
I haven't seen my car in person yet but I think they run
225/45-18s front and 245/45-18s rear but it depends on what the tyre placard the compliance shop fits says
Cheers
they run
225/45-18s front and 245/45-18s rear Cheers
That's confirmed as far as sizing goes.
At present I would be happy just to source a good set of road tyres at the right price .
Cheers
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
