Got my car dynoed at Power Tune last Sunday and it pinged pretty bad after 200kw. Was told by the mechanic there that the exhaust manifold is restrictive. Not saying he is wrong (the manifold could be the problem) but I thought stock manifold should be good enough for up to more than 250 kw ? Anyway I was also told that the turbo could flow more than 207kw as dynoed and may not be stock R33 turbo (same as what Hitman said) . I'm just confused as to what could make the car ping, is it timing (coz stock ecu), sparks ? Car wasnt running lean coz a ratio is less than 12:1.
My guess is coz the stock ECU and the timing is screwed. And if the turbo is actually not stock R33 then with a powerfc it could probably push up to 230kw ( I have to save up for that). By the way my mods are: full 3" zorst, panel filter, fmic, 500hp fuel pump, SAFC, bleed valve @ 12 psi, possible bigger injectors.
Here's the dyno result at Power Tune (non shoot-out) made 207kw and with Hitman about 2 months ago (shoot-out) made 212kw
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/
207 with a stock ECU/12psi hhmm... i'd find out, certainly doesnt sound like a stocker turbo, figures are a "tad" hight.
If the car is pinging however, itll be the tuning of the SAF-C, or your fuel system isnt correct. Either way it comes back to the tuner and the work done (or not done)
Its probably a minor adjustement, if its audible pinging though... i'd be very worried
And i dont mean to sound negative, but thats not the best SAF-C tune in the world either, the line is all over the joint.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702011
never heard of the manifold causing a car to ping.. but i have seen the std log style manifold running over 250 rwkw. so that wouldn't be causing it..
seems that Hitmans tune was a bit better than the recent one too. since the power curve is alot smoother. and still alot of fuel up top to keep it safe
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702070
intake temp is also 53deg which is fairly high. what air intake setup do you have? you can make 250rwkw with stock ecu remapped and a larger turbo but not with stocker turbo. with the same mods and powerfc youll make 200rwkw but the tune will be very aggressive and spot on. it will be a dream to drive and it will feel strong all the way through the rev range.
based on the graph its looks like the tuner has to juggle the load points around too much with the safc and the stock ecu trying to control stuff.
heres a powerfc rb25 with basically the same mods
http://members.dodo.com.au/paul/pics/dyno/...r33-193rwkw.jpg
sure it makes 8 or 9rwkw less but you can see the graph is strong all the way through and i have stacks more average power. from 130km/h to 170km/h i have pretty much the same power
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702432
The Hitman's tune was done earlier when installing SAFC, the one with Power Tune was purely a power run. Ye I'm also not sure how can the curve look so crap after 2 mths without even touching the tune.
I have the stock air box with the front snorkle taken out due to fmic. Intake temp was high with Hitman's tune coz he dynoed it with the bonnet closed. You r right Paul with PFC it would definitely drive less jerky as it is now. And I wouldnt be worry about the difference btw top ends of PFC and SAFC unless the turbo isnt stock. Can the PFC fix the pinging problem?
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702477
if the tuner is telling you its pinging because of the exhaust manifold, then I'd finding another tuner. Thats a crock of shit.
I made 210rwkw on a stock turbo with a powerfc etc.
12psi is pretty high for a stocker, and pretty mcuh its limit before it turns itself into a big heat pump, and starts the detonation.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702572
you should look at a proper cold air intake as it will be sucking it hot air (ive got the same problem). theres a fairly big different in driveability stock ecu vs powerfc. once you have all the load points in the powerfc maps tuned it's like a whole new car. the dyno graph doesnt do its justice really. as all you are (and everyone else for that matter) looking for is max power. id rather have a little less max power and stacks more average power and have awesome drivability and snappy throttle response
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702635
shouldnt ping heres mine with stock turbo and remapped ECU
http://image-cache.skylinesaustralia.com/f...-1128947661.jpg
That's very good power with stock turbo, was it running out of puff at the end? Is hat tuner in NSW?
I wasnt going the for a tune, it was like a dyno competition. But ye he probably doesnt know about R33 manifold's limit. I know 12 psi from most ppl say is the limit for stock turbo but if it can still flow more then may be it isnt stock right??
Try re-setting your ecu, it might be trying to overcome the changes made through the SAFC over time. When your car pings the stock ecu also retards the timing.
Thx for mentioning that, I'll give it a try. Looks like the stock ECU wasnt trying to "adapt" to change but instead making it run worst . . .
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702636
thats right it could also be the hot air that holding it back/pinging. But I'm having the stock air box now and most custom cold air box are made for pods. Air there any box out there that is made for panelt filters?
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702667
12psi isnt really a limit. its more of a theoritical limit. the heat associated with running 12psi will cause the stocker exhaust wheel on the turbo to basically fail, thus the turbo dies. that being said 12psi on a cold night might be ok but 12psi on a hot summers may soar the intake temps up and generate lots more heat. its not a "fixed psi limit" like most poeple think. and because mr xyz can run 12psi on his r33 series2 and it doesnt die doesnt mean you can do the same and it will be exactly the same, as it wont. a tune can greatly affect the exhaust temps, thus affecting the temp on the exhaust wheel.
if you arent sure if its a stocker turbo or not take off the airflow meter to turbo ducting and look at the turbo inlet and housing. it should have oem hitatchi markings and v42.5 or somthing to that affect
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702682
No the tuner is in Japan Nerve Essential ECU remap, just started to drop off at 7k
If mine was pinging and the were saying that its the stock manifold tell that there are plenty of gtst's running the 300rwkw mark and above with t04 so go find a new person.
Good luck with it.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702694
you can get hiflow panel filters to suit the stock airbox, which are great
Cheers, I'll look that up
Good luck with it.
If your ur stock ecu is remapped in Japan how can it be tuned to aust fuel and other things? I wish mine could have bonus like ecu when it was imported here, well at least I hope the turbo is.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702800
jap tuned ecu's are not always good, like the mines remapped ones. as they are tuned on jap RON fuel counts and and can't alter / edit them without mines software so its basically useless. cant sell it for much either as nobody can use it properly
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702876
Hiflowed like mine
when they go in japan they will hiflow its cheaper
Gaps on plugs but i think you are pushing too much without the proper suport mods
we all like saying mine got 250rwkw 4 not many mods but you can stuff them up that way
(fuel systems and ecu at least)
take my advice turn your boost down too 10psi max
do it slowly and remember a dyno is not everything
james
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1704519
for some reason mine runs well as seen on the graph, that was for a dyno day here in Canberra.  Maybe someone retuned it here before i got it.
Good luck post up how you go getting this sorted.
Thx, will keep updates.
Hiflowed like mine
james
Ye dyno figures are just tuning guides but I'm having the boost down to 10 psi now. Hell even set at 12 psi the max when I floored it were only at 8 or 9 psi with my granny shifting. For daily driving expecially in summer I dont think anyone would constantly push their cars to that much boost in traffic.
So your car was hiflowed back in japan? I hope mine is . . .
Edited by JeeTeeEss25Tee
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1705760
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
