Got my car dynoed at Power Tune last Sunday and it pinged pretty bad after 200kw. Was told by the mechanic there that the exhaust manifold is restrictive. Not saying he is wrong (the manifold could be the problem) but I thought stock manifold should be good enough for up to more than 250 kw ? Anyway I was also told that the turbo could flow more than 207kw as dynoed and may not be stock R33 turbo (same as what Hitman said) . I'm just confused as to what could make the car ping, is it timing (coz stock ecu), sparks ? Car wasnt running lean coz a ratio is less than 12:1.
My guess is coz the stock ECU and the timing is screwed. And if the turbo is actually not stock R33 then with a powerfc it could probably push up to 230kw ( I have to save up for that). By the way my mods are: full 3" zorst, panel filter, fmic, 500hp fuel pump, SAFC, bleed valve @ 12 psi, possible bigger injectors.
Here's the dyno result at Power Tune (non shoot-out) made 207kw and with Hitman about 2 months ago (shoot-out) made 212kw
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/
207 with a stock ECU/12psi hhmm... i'd find out, certainly doesnt sound like a stocker turbo, figures are a "tad" hight.
If the car is pinging however, itll be the tuning of the SAF-C, or your fuel system isnt correct. Either way it comes back to the tuner and the work done (or not done)
Its probably a minor adjustement, if its audible pinging though... i'd be very worried
And i dont mean to sound negative, but thats not the best SAF-C tune in the world either, the line is all over the joint.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702011
never heard of the manifold causing a car to ping.. but i have seen the std log style manifold running over 250 rwkw. so that wouldn't be causing it..
seems that Hitmans tune was a bit better than the recent one too. since the power curve is alot smoother. and still alot of fuel up top to keep it safe
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702070
intake temp is also 53deg which is fairly high. what air intake setup do you have? you can make 250rwkw with stock ecu remapped and a larger turbo but not with stocker turbo. with the same mods and powerfc youll make 200rwkw but the tune will be very aggressive and spot on. it will be a dream to drive and it will feel strong all the way through the rev range.
based on the graph its looks like the tuner has to juggle the load points around too much with the safc and the stock ecu trying to control stuff.
heres a powerfc rb25 with basically the same mods
http://members.dodo.com.au/paul/pics/dyno/...r33-193rwkw.jpg
sure it makes 8 or 9rwkw less but you can see the graph is strong all the way through and i have stacks more average power. from 130km/h to 170km/h i have pretty much the same power
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702432
The Hitman's tune was done earlier when installing SAFC, the one with Power Tune was purely a power run. Ye I'm also not sure how can the curve look so crap after 2 mths without even touching the tune.
I have the stock air box with the front snorkle taken out due to fmic. Intake temp was high with Hitman's tune coz he dynoed it with the bonnet closed. You r right Paul with PFC it would definitely drive less jerky as it is now. And I wouldnt be worry about the difference btw top ends of PFC and SAFC unless the turbo isnt stock. Can the PFC fix the pinging problem?
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702477
if the tuner is telling you its pinging because of the exhaust manifold, then I'd finding another tuner. Thats a crock of shit.
I made 210rwkw on a stock turbo with a powerfc etc.
12psi is pretty high for a stocker, and pretty mcuh its limit before it turns itself into a big heat pump, and starts the detonation.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702572
you should look at a proper cold air intake as it will be sucking it hot air (ive got the same problem). theres a fairly big different in driveability stock ecu vs powerfc. once you have all the load points in the powerfc maps tuned it's like a whole new car. the dyno graph doesnt do its justice really. as all you are (and everyone else for that matter) looking for is max power. id rather have a little less max power and stacks more average power and have awesome drivability and snappy throttle response
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702635
shouldnt ping heres mine with stock turbo and remapped ECU
http://image-cache.skylinesaustralia.com/f...-1128947661.jpg
That's very good power with stock turbo, was it running out of puff at the end? Is hat tuner in NSW?
I wasnt going the for a tune, it was like a dyno competition. But ye he probably doesnt know about R33 manifold's limit. I know 12 psi from most ppl say is the limit for stock turbo but if it can still flow more then may be it isnt stock right??
Try re-setting your ecu, it might be trying to overcome the changes made through the SAFC over time. When your car pings the stock ecu also retards the timing.
Thx for mentioning that, I'll give it a try. Looks like the stock ECU wasnt trying to "adapt" to change but instead making it run worst . . .
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702636
thats right it could also be the hot air that holding it back/pinging. But I'm having the stock air box now and most custom cold air box are made for pods. Air there any box out there that is made for panelt filters?
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702667
12psi isnt really a limit. its more of a theoritical limit. the heat associated with running 12psi will cause the stocker exhaust wheel on the turbo to basically fail, thus the turbo dies. that being said 12psi on a cold night might be ok but 12psi on a hot summers may soar the intake temps up and generate lots more heat. its not a "fixed psi limit" like most poeple think. and because mr xyz can run 12psi on his r33 series2 and it doesnt die doesnt mean you can do the same and it will be exactly the same, as it wont. a tune can greatly affect the exhaust temps, thus affecting the temp on the exhaust wheel.
if you arent sure if its a stocker turbo or not take off the airflow meter to turbo ducting and look at the turbo inlet and housing. it should have oem hitatchi markings and v42.5 or somthing to that affect
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702682
No the tuner is in Japan Nerve Essential ECU remap, just started to drop off at 7k
If mine was pinging and the were saying that its the stock manifold tell that there are plenty of gtst's running the 300rwkw mark and above with t04 so go find a new person.
Good luck with it.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702694
you can get hiflow panel filters to suit the stock airbox, which are great
Cheers, I'll look that up
Good luck with it.
If your ur stock ecu is remapped in Japan how can it be tuned to aust fuel and other things? I wish mine could have bonus like ecu when it was imported here, well at least I hope the turbo is.
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702800
jap tuned ecu's are not always good, like the mines remapped ones. as they are tuned on jap RON fuel counts and and can't alter / edit them without mines software so its basically useless. cant sell it for much either as nobody can use it properly
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1702876
Hiflowed like mine
when they go in japan they will hiflow its cheaper
Gaps on plugs but i think you are pushing too much without the proper suport mods
we all like saying mine got 250rwkw 4 not many mods but you can stuff them up that way
(fuel systems and ecu at least)
take my advice turn your boost down too 10psi max
do it slowly and remember a dyno is not everything
james
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1704519
for some reason mine runs well as seen on the graph, that was for a dyno day here in Canberra.  Maybe someone retuned it here before i got it.
Good luck post up how you go getting this sorted.
Thx, will keep updates.
Hiflowed like mine
james
Ye dyno figures are just tuning guides but I'm having the boost down to 10 psi now. Hell even set at 12 psi the max when I floored it were only at 8 or 9 psi with my granny shifting. For daily driving expecially in summer I dont think anyone would constantly push their cars to that much boost in traffic.
So your car was hiflowed back in japan? I hope mine is . . .
Edited by JeeTeeEss25Tee
https://www.sau.com.au/forums/topic/94293-car-pinged-200kw/#findComment-1705760
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
