The RB configuration due to it being a six cylinder 2 litre has shorter strokes so off the factory its lacking in torque and yes less than the sr20det.
The RB revs out very nicely though and isnt so weazy.
The RB bottom end is probably stronger being cast iron.
The SR has the potential to go 350-400hp stock but then again so does the RB.
I personally would go with the RB because its just a better starting point.
I do like the timing chain setup on the ser20det because it doesnt cost money to change it on the 100 k service.
But end of the day its how much money you have and both motors are very reliable.
https://www.sau.com.au/forums/topic/943-rb-vs-sr/#findComment-20391
13b kills em but the seals go if you drive 'em hard. as with all rotary / wankel designs.
and if you get even mild pinging..... cyal8r 13b.
besides that 350hp+ out of a 13b can be considered pretty stressful (i mean its no v8!) but you'll be lighter... and a rebuild won't cost as much.
but when all is said and done: if u want something that goes damned fast and lives 2-3 times longer than a 13b, go the sr or rb.
https://www.sau.com.au/forums/topic/943-rb-vs-sr/#findComment-20597
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
    • This is what I've done, add DC until it meets my fuel pressure requirements and above 4500 at over 1bar of boost, I send its mum with 100% DC to both pumps. I'll post up a table soon when I'm free.
