I have heard it mentioned on here before, however there isn't a topic discussing its pros and cons.
I have started and ran my rb26 a couple dozen times for a total of maybe 30minutes. This may be the first time the engine has run in years (no history). I'm getting my driveshaft back tomorrow and will be taking the engine and car for it's first spin.
I would like to make sure the motor is free of sludged oil and give it a good flushing. I have heard the 1 quart diesel fuel to 4 quarts standard oil is good. My plan is to drive it 15 miles down the road with the fuel in it and get it changed at the local dealership. (can't wait to see the look on their faces LOL)
Is this safe?
Is it the best way to go?
I have heard that this will help reseat the rings if needed.
Do I have the right fuel to oil ratio?
Will 15 miles (20 minutes) be too long? not long enough?
https://www.sau.com.au/forums/topic/94323-diesel-fuel-in-motor-oil/
i wouldn't do it. mainly because i don't fully understand what negative effects it could have. I have previously used wyns oil flush before with good results. but my advice is to crank the engine a little to build some pressure, take it for a 15min drive, come back, drop the oil and change the filter then re-fill with your new oil.
If no one here has tried it, and we're all a little leary about it, what engine flushing products out there do you recommend.
p.s. this is an old timer's trick, my Great Grandfather used mineral oil. Funny thing is, he always went overboard, so if 2 cups was good, then 2 quarts must be better. They let it sit running for 45minutes until they heard *clackity clackity CLUNK* Siezed the motor!! LOL
Your choise , I would not put diesel fuel anywhere near the sump . Diesel fuel is exactly that - fuel not lubricating oil so no guarantees it will lubricate . It will thin the oil down thats for sure .
My own experience was to use diesel engine OIL but only because it was a high detergent type used in EMD/GE locomotive diesels .
If I was you I'd run reasonable engine oil in it and change it and the oil frequently for a while . The only way without opening it up to remove gunge is by draining the oil and changing the oil filter .
Cheers A .
Plenty of people have done it.
of course, most of those people own diesel vehicles (and usually older ones)
from what I understand blowby of diesel can get into the engine oil.
and it could combust. Ever wondered why even on modern diesel vehicles they have such a short oil change limit?
if you DO decide to try it, remember diesel combusts under pressure. it doesn't need a spark to ignite.
All I can say it, no way in hell I would do it.
Probably the safest way to thin the oil is to use some ATF. Its safe for a flush cos it still has antiwear/seal swelling (etc) additives and yeah, I'd try no more than a 50/50 dilution with normal oil. If you are a tight ass, you could try adding a litre of kerosene but it may screw up your seals...
LOL, tight ass, nah, just looking for some good old proven methods.
hmm, not sure about that one. For example, I know that if you add brake fluid to hydraulic oil (we're talking 2 teaspons to 3 gallons) it'll cause the rubber seals to swell enough to temporarily stop leaks.
I'd be a little over cautious about adding that one, unless ofcourse, somebody has had experience with it.
The problem with "flushing" your engine like that is all the bits of sludge etc that you dislodge end up somewhere, usually blocking fine oil passages etc. I strongly advise you not to do this. If you must try and clean it out you could use an engine oil developed for diesel engines such as castrol rx super(providing the viscosity is correct), diesel engine oils have a very strong detergent content. But I wouldn't even do that.
You should just use a high quality engine oil and change it after a thousand kays or so.
If you really are paranoid about sludge or whatever have the engine torn down and cleaned/inspected.
Just my opinion/thoughts.
Graham
ok.. was discussin this with a mate the other night.. use the wyns flush stuff let it idle for 10 minutes turn off and usual change oil and filter
a mate put it in and left it in for a couple days the engine devoloped a massive knock and overheated pretty bad (240 farrenheight dunno wat that is in celcuis) that was in a old 308 thats been cained constantly for 8 years since it was built when the oil was dumped it was like water.. not good so yer if you wanna do it let it idle for 10 minutes with the stuff in it than drop it change filter and put new oil in
Wazz
Well thank you, questions answered!!!
I will just go with the normal oil change, just every 500miles a couple times. I'll stick with normal oil as well since synthetic's don't have a lot of detergents in them.
Thanks again.
See you on the flip side.
your running a fairly high tech multi valve turbocharged motor and your gonna run a mineral oil in it. Mate its not a commo or falcon sorry gm/chev/ford. you wanna give it a good sporting chance by using full synthetic oil or some form with the right viscosity. You may even have to use a slightly thicker grade if the engine is a little old and worn.
LOL synthetics dont have a lot of detergents in them? Seems like you need some re-education :D
Synthetics almost always contain higher amounts of detergents in them compared to mineral oils...
You're right, I don't know what I was thinking. Hence, switching from a mineral based oil in an old engine to straight synthetic can cause chunks of buildup to lift off into the motor. I'm running around here at the shop with an average of 3hrs of sleep a night (often getting online before I head home) getting this car on the road. I won't even bother to explain the super tired line of thought.
I fully plan on using some high grade synthetic!!!!! Just not to flush the motor out. Granted the motor is used, but I want to treat it like a brand new motor which would require a mineral based oil to break in properly. Plus I don't see the need for a good synthetic when I'm going to be dumping it in 500miles anyways.
try using a qt of kerosene, its been done before and a national parts chain's engine flush is mostly kerosene.
works well, just dont run the motor under load and change the oil right afterwards but allow for a good draining as you want as much of the kero/oil mix out of the motor.
Synthetics breaking off 'chunks' of crud in a high mileage motor is nothing but a stupid myth. If anythings gonna do it, its your idea of throwing in kerosene or diesel fuel into your motor. :huh:
The detergents in oil do almost nothing for existing deposits. Rather, they help prevent them instead by keeping the contaminents in suspension. Once they deposit and form varnish or sludge, these detergents cannot do anything about them. Besides, PAO base oil synthetics have a low solubility coefficient and thus dont readily dissolve crud anyway. They're good at not leaving them there in the first place.
Edited by Busky2k
hehe, i didnt reccomend he use it now...... :(
engine flushes are shit. only good if the motor has low kays.
all the crap that it cleans off ends up bieng jammed i the crankshaft and blocking it. thats why peaple "grub screw the crank" so yoy can remove them and clean the sludge out.
just use a good quality semi or full synthetic.
my 32 gtr has done 160000kms and i use penrite syn 5 (5w-60) and it works a treat.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
