Hi Guys,
Im building my engine and i was wondering if anyone has built an RB26/30 engine using a CR of 9 or close to 9?
My engine mods are:
Top End
RB26 Head fully serviced and mildly ported
HKS 272 Step 1 Cams
HKS Cam Gears
Bottom End (fresh rebuild)
RB30 Bottom End
Forged H-Beam Rods
Forged Pistons
O-Ringed Block
ACL Race Series Bearings
Oil Pump Drive Collar
R33 GTR Oil Pump
Oil Restrictors for the Head
Fully Balanced
Intake/Exhaust
Garrett T04Z 1.00 Rear
6Boost Manifold
XTR 55mm Wastegate
600x300x100 Tube/Fin Intercooler
ARC Air Box
3.5" Exhaust System
Fuel System
Bosch 044 Fuel Pump
700cc Injectors
Nismo Fuel Reg (Adj)
ECU
Apexi Power FC
Q45 Air Flow Meter
The reason i ask this question is if i can run a CR of as close to 9.0:1 as possible i hopefully can make my target power of 400kw at all four wheels with only using 16psi on pump fuel.This is going into an R32 GTR
I appreciate that this is very dependant on how good the tuner is, i will be using a very reputable tuner who has good experience with tunning GTR's
Edited by GTR_Junkie
https://www.sau.com.au/forums/topic/94347-rb30det-with-a-cr-of-901/
my dad runs his gtr's at about 10:1 and is looking at making them even higher think he wants 11.5:1..
r32 gtr n1 spec engine and turbos it makes max power of 254kw at all 4 wheels at 5100rpm and full boost at 3700rpm of around 24-28psi.
has full motec ecu with logging race dash and according to the logging it should run mid 11's down the 1/4mile
SSS_Hoon
mid 11's with 250awkw?  and 250awkw on 24psi from N1 turbos?
good son of rajab something isnt right there... power should be over the 300 mark with N1's and that higher boost lvl
LOL thats exactly what i thought :lol:
over 9:1 is getting a bit high for a street car, and will be boost limited if using pump fuel IMO. The last time i heard 11.5:1 was when talking about a 350 Chev smallblock! Isnt that too high in a turbo RB application?
9:1 however should be great! You should easily meet your target, even with a lower CR. So far results from the TO4Z have been awesome (drool at R32-GTS's results). You "might" need a smidgen more boost than 16psi..
SSS_Hoon
sniff sniff..
can anyone else smell that?
:D
Gibson also rebuilt their engines every race meeting, oh and it was a race car running race fuel, we are talking street cars here that have limited fuel choices. Anything over 9.0-9.5:1 in a turboed street car is stupid and dangerous when running upwards of 15psi!!! Its basically common physics that come into it if you look into the heating rate of compressed air, ie boosted air, then add to that compression ratios of 10+ you are running well over 180-190psi in each cylinder, and no fuels you can use legally on the road are going to burn properly at those pressures. In long 9.0:1 will be great for your application GTR Junkie, as yu will still have a nice car off boost that will be really responsive. How are you planning to run it in your GTR you should swing me a PM, as its good to start the mods at machining stage if possible!!!
How will he machine down the block if the pistons are running the 0 deck clearance as the pistons should be to achieve the correct squish.
Unless that is he decides to use RB26/rb25 pistons that have a different pin height, causing the piston to sit lower in the bore.
Then machining down the block to achieve a nice squish and resulting in a slightly higher comp ratio..
Why not simply order custom pistons to suit? :huh:
Because if you machine te block to acieve a higher CR, most off the shelf pistons run at 0 deck height to achieve a good squish area with standard type machine work. If he machines the block lower to sit the piston higher in the bore the pistons will sit proud of the block and you will have less squish you can compensate by running thicker head gasket to get it back but then the CR falls as well and you end back to where you started!!!!
    • Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
    • I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
