Rb30det With A Cr Of 9.0:1 ?
GTR_Junkie
 Share
Gibson also rebuilt their engines every race meeting, oh and it was a race car running race fuel, we are talking street cars here that have limited fuel choices.
I got no idea what compression ratio is ideal, but the Group A cars were meant to be running on control Shell fuels. I seem to recall the fuel was not too exotic, actually i dont recall there being any mention of a fuel change when they changed from Grp As to V8s and these days they do run Shell Optimax. What the equivelant back in 90-93 was im not sure, but it wasnt too exotic
why do you want to run such a high C/R anyway? sacrificing reliabilty, my motor is 30/25 i have a C/R of 7:1 as it allows me to run higher boost and then bring my to4e66 turbo into range(round 25psi) allowing it to make good power. 480bhp with standard manifold, standard cams and stock camgears!
The bathurst sierra cosworths ran 5:1 C/R allowing it to run up to 45psi boost to bring the turbos into range!
Stick with the 9:1 it will work well, especially with a set of lumpy sticks.
Problem is there are no on the shelf pistons that get anywhere near that.. 8.6:1 I think is the closest you will get.
Unless CP's run some wierd pinheight, dome config.
it may not need to be that low but as it is my daily driving car on pump fuel with no additives it suits my purpose and i still have full boost by 3000rpm! and i have a mate of mine with a vl that had 9.5:1 c/r making 400bhp on 22psi and he melted 2 pistons as apposed to any mate of mine that has the exact same setup except he was running 7.8:1 c/r making 412bhp on 26psi and hasn't had a drama so imo i'd rather be on the safer side rather than pushing it to the brink! But that's just me :)
One solution is JE forged VG30DETT pistons at 87.5mm . The gudgeon pins are larger so rods need work .
If boost pressure is a measure of resistance to airflow then high boost is a lame excuse to get more air in . If you reduce the resistance to flow then same volume at lower pressure will make everything else easier . High boost pressure needs high fuel rail pressure/expensive pumps/expensive fuels/etc .
The RS500 YBD engine had a dog of a turbo making an unreliable pig of an engine for road or Grp A . You need to look at better examples than this .
Cheers A .
I was talking to Mick from Rocket Industries and he emailed me this:
The RB25 head has a a larger combustion chamber than the the RB26.
The dome on the AP332104 is .110" high. The dome on the AP332105 is .155 high. This will give more comp.
I spoke with our RB expert here and he reckons that the AP332105 might be a better option.
I believe the AP332104 are ARIAS pistons that give 8.5:1 CR and AP332105 are pistons that are used for RB26/30 convertion. I was advised to use the AP332105 pistons for RB25/30 convertion. Two questions though:
1. What kind of CR would this give
2. Would the higher piston sit proud of the block requiring thicker metal head gasket
Still... I wouldn't be going by what some one says..
Its much safer to simply measure it all up, you then know what + or - dome required. My Rb25 head cc'd up at 62.2cc's.
The Rb25 and 26 pistons also vary in their Pin height. So this is something also to look at if you want to optimize squish, which why wouldn't you for a little bit of research. :(
Edited by Cubes
 Share
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
    • I would say 100% that it doesn't matter at all. I have an Al bonnet and I drop it sometimes, push it others. Have done so for 25 years and there's no way to tell that either has caused any problems (because there are no problems).
    • yeah, a black 4 door HR, stock AT RB20DE. Was a pretty good daily summer car, it was kept in a garage during winter but previous owner was fighting rust so most of the car was covered with rust undercoating, the trunk, floorpan, it started to rust underneath so I thought it would be better to find other chassis that was taken care better and do rust preventions myself, at least I would know where keep my attention at. Plans are simple, enjoy the car as much as I can, mostly on summer of course, winter here is long and not kind to 90s JDM, I wanna keep it mostly stock like, I'm not a huge fan of GT-R look or any body kits so gonna keep it as metal as possible haha, something more balanced look wise and yeah, work on performance, I was thinking about RB25DET but 20DET actually feels fun, as long as it's reliable I think I might keep it.
