Gibson also rebuilt their engines every race meeting, oh and it was a race car running race fuel, we are talking street cars here that have limited fuel choices.
I got no idea what compression ratio is ideal, but the Group A cars were meant to be running on control Shell fuels. I seem to recall the fuel was not too exotic, actually i dont recall there being any mention of a fuel change when they changed from Grp As to V8s and these days they do run Shell Optimax. What the equivelant back in 90-93 was im not sure, but it wasnt too exotic
why do you want to run such a high C/R anyway? sacrificing reliabilty, my motor is 30/25 i have a C/R of 7:1 as it allows me to run higher boost and then bring my to4e66 turbo into range(round 25psi) allowing it to make good power. 480bhp with standard manifold, standard cams and stock camgears!
The bathurst sierra cosworths ran 5:1 C/R allowing it to run up to 45psi boost to bring the turbos into range!
7.1 holy god, that would be a pig of a car off boost.
I aint heard of that since the VL boys out West and thier "fully sick decomp plate" for 11ty billion psi
You dont need it to be that low at all for 25psi
Stick with the 9:1 it will work well, especially with a set of lumpy sticks.
Problem is there are no on the shelf pistons that get anywhere near that.. 8.6:1 I think is the closest you will get.
Unless CP's run some wierd pinheight, dome config.
it may not need to be that low but as it is my daily driving car on pump fuel with no additives it suits my purpose and i still have full boost by 3000rpm! and i have a mate of mine with a vl that had 9.5:1 c/r making 400bhp on 22psi and he melted 2 pistons as apposed to any mate of mine that has the exact same setup except he was running 7.8:1 c/r making 412bhp on 26psi and hasn't had a drama so imo i'd rather be on the safer side rather than pushing it to the brink! But that's just me :)
One solution is JE forged VG30DETT pistons at 87.5mm . The gudgeon pins are larger so rods need work .
If boost pressure is a measure of resistance to airflow then high boost is a lame excuse to get more air in . If you reduce the resistance to flow then same volume at lower pressure will make everything else easier . High boost pressure needs high fuel rail pressure/expensive pumps/expensive fuels/etc .
The RS500 YBD engine had a dog of a turbo making an unreliable pig of an engine for road or Grp A . You need to look at better examples than this .
Cheers A .
I was talking to Mick from Rocket Industries and he emailed me this:
The RB25 head has a a larger combustion chamber than the the RB26.
The dome on the AP332104 is .110" high. The dome on the AP332105 is .155 high. This will give more comp.
I spoke with our RB expert here and he reckons that the AP332105 might be a better option.
I believe the AP332104 are ARIAS pistons that give 8.5:1 CR and AP332105 are pistons that are used for RB26/30 convertion. I was advised to use the AP332105 pistons for RB25/30 convertion. Two questions though:
1. What kind of CR would this give
2. Would the higher piston sit proud of the block requiring thicker metal head gasket
Still... I wouldn't be going by what some one says..
Its much safer to simply measure it all up, you then know what + or - dome required. My Rb25 head cc'd up at 62.2cc's.
The Rb25 and 26 pistons also vary in their Pin height. So this is something also to look at if you want to optimize squish, which why wouldn't you for a little bit of research. :(
Edited by Cubes
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
