Item:17" Rims
Item Condition:
Reason for Selling:Other Rims i want
Price and Payment Conditions:$800
Contact Details:0415557891
hey
wanting to sell my rims because a friend has some i like better
17x8 on the front with +32 offset and 17x9 on the rear with +38 offset with a good 10cm of dish on the rear and about half that on the front
to suit a R32/33/34 skyline 5 stud
comes with tyres
215/40 toyo proxes with 40% left on the front and rears willbe 255's off the rims i get if these sell which are 255/45 with 80% tread
255's scraped the guards on my 32 but since i put 235's on the rear it doesnt scrape
wanting $800 or there abouts
www.lexicon.net/scari/new32.jpg for a pic
https://www.sau.com.au/forums/topic/94367-fs-wed-sports-rs-5-17-deep-dish-rims/
  • 3 weeks later...
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
