Hey all
I just recently got my R33 GTS-T back after 2 weeks off the road to replace a blown turbo.... and after 10 mins of driving it i blew a rear tyre.
I was told (and shown) by my local tyre place that the inside wall of all four tyres are cracked... and the rear left on was so cracked it blew, and the other rear one was on its way out so it was replaced as well.
The problem is.... i paid $350 EACH for these tyres in march of this year, and they have travelled only 20 000kms from new...
They are Falken... 235/45ZR19... and they guy said the cracking is due to such an extremely low profile... but i realised to myself afterwards that the tyres that were on the car before i replaced the whole set were the exact same tyres and had no cracks whatsoever, only the tread was worn to dangerous levels...
And the tread on the tyres i just had replaced was fine...?
Im confused... should the above mentioned tyres lasted more than 20 000kms? Remembering tread is fine....
Car in stock, unmodified...
https://www.sau.com.au/forums/topic/94378-tyre-blowout-after-20-000-kms/
Hey all
Interesting i've got the same tyres but in 235/45/17 i wouldnt call them extreemly low profile though as i've seen 35's too and theres a large difference.
This happened to my mate (crack then blow out) who ran kuhmos at a 35mm profile he took the tyres back to the seller and he replaced them for him for free with sumitomo's I think.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
