Hey all
I just recently got my R33 GTS-T back after 2 weeks off the road to replace a blown turbo.... and after 10 mins of driving it i blew a rear tyre.
I was told (and shown) by my local tyre place that the inside wall of all four tyres are cracked... and the rear left on was so cracked it blew, and the other rear one was on its way out so it was replaced as well.
The problem is.... i paid $350 EACH for these tyres in march of this year, and they have travelled only 20 000kms from new...
They are Falken... 235/45ZR19... and they guy said the cracking is due to such an extremely low profile... but i realised to myself afterwards that the tyres that were on the car before i replaced the whole set were the exact same tyres and had no cracks whatsoever, only the tread was worn to dangerous levels...
And the tread on the tyres i just had replaced was fine...?
Im confused... should the above mentioned tyres lasted more than 20 000kms? Remembering tread is fine....
Car in stock, unmodified...
https://www.sau.com.au/forums/topic/94378-tyre-blowout-after-20-000-kms/
Hey all
Interesting i've got the same tyres but in 235/45/17 i wouldnt call them extreemly low profile though as i've seen 35's too and theres a large difference.
This happened to my mate (crack then blow out) who ran kuhmos at a 35mm profile he took the tyres back to the seller and he replaced them for him for free with sumitomo's I think.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
