Hey guys, right now im lookin at buying a R32 gtst (probably a 4 door due to budget restrictions). Now i had a look at a couple from Yahoo Motorsport and i liked them. However, beofre i go bore John V. to hell, i thought i'd ask for some advice:
1. How much is auto to manuel conversion on a r32 gtst 4 door. (average price for everything, to buy the transmision and to pay a mech. to do it)
2. How easily do they get through regency (easier to do b4 mauel conversion?).
3. How much is it to go through regency (approx.) - im hoping it can be done under $1200.
4. Anything else you think is important b4 i make a descision.
Thanks heaps.
https://www.sau.com.au/forums/topic/94394-some-help-please/
wouldnt it be easier to just buy a manual one?
All the manuels are sold on Yahoo Motorsport, and im not a big fan of buying imports b4 i can actually see them and inspect them.
If you PM me some contact details i may be able to put you onto aposible sale of the best 4dr in this state and its already reg here and it's a manual...
  Regards,
            SKYLINE (Kym)... B)
Would be nice, but i dont think i can afford that atm. Thanks anyway.
manual conversion in mechanics would cost thousands and not to mention it will definatly cost you 1200 to comply.
just spend that couple of  grand on a better car! :D
True.
Cheers guys.
https://www.sau.com.au/forums/topic/94394-some-help-please/#findComment-1704569
i got my 33 4 sale, its non turbo, but in excelent condition and looks good...
look here
http://www.skylinesaustralia.com/forums/in...showtopic=93679
http://www.carsales.com.au/pls/carsales/...icle_id=2329332
not worth converting to manual, 2 much hassle...
https://www.sau.com.au/forums/topic/94394-some-help-please/#findComment-1704966
getting the car ready for regency can be done for $900ish or even less if you do the work your self and just get it signed off. My man conv cost me $1450 including gearbox through FBI buying a auto 32 is the way to go as they are usually (in my case anyway) in better mechanical condition. However make sure you look the car over very well! i.e under the car as well for rust and damage
https://www.sau.com.au/forums/topic/94394-some-help-please/#findComment-1705301
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
