After alot of deliberation, My wifes' car is being put up for sale.......I cannot stress enough that we are looking for a good home for this vehicle. My wife has spent countless hours pampering this car. eg: car is always washed, and gets polished once a month. This is her baby.
R32 Gtst
117,000klms (100k service, Cambelt changed etc at WASP Performance)
Serviced every 5000klms with quality Mobil Oil
Recently fitted FMIC with polished alloy piping.
HKS Air filter
TEIN Height AND Damper adjustable coilovers all round
18 x 8 inch Alloys with near new (3000k old) PIRELLI Tyres.
3" exhaust with new 3" high flow "cat"
Type M front bar.....with RARE factory 4 door side skirts. (skirts supplied but not fitted or painted, never got around to it)
Bride Brix Drivers seat (Mod plated)
GTR Passenger seat (Mod plated)
GTR Fuel Pump
GReddy Boost Guage
HKS Turbo Timer
Cusco Strut braces front and rear
Kenwood Double DIN audio
Full window tint
Alarm and immobiliser fitted approx 6 months ago. (not a crappy one)
Fresh Yellow Paint with Black Bonnet with effect paint. (sort of like a very fine glitter, but better :D )
Has rego till MAY 2006!!!!!!!! (Qld)
Reason for selling.........Don't want to sell but we needed a Tow car, and also something that will comfortably transport babies :)
Price: $16,500
We are NOT looking for swaps of ANY kind, as we have already purchased a new vehicle. Straight sale only.
If you have any further queries, please contact me on 0402 807 417
Regards
Nico
Edited by RiverSide
https://www.sau.com.au/forums/topic/94412-r32-gtst-5-speed-4-door-modified/
I can't believe this is not sold yet......I understand it is not the cheapest available......but it is certainly one of the best (in my opinion, and i have seen a few :( )
Come and buy a QUALITY car......You know you want to :)
hey mate
i got a friend interested but she doesnt get much net access and she's quite busy with work.
just a couple of quick questions,
how negotiable on price are you?
who did the paint job and how long ago etc?
what was done on last service?
and any pics of the skirts?
Cheers
There is always a little bit of movement on the asking price.....but rediculous/insulting offers will not be entertained. (Had a few already)
Vehicle was painted about 12 months ago....always garaged since and polished every month.
Vehicle had Timing belt changed at 104k. (water pump done as well, was not busted but figured we might as well do it while all the belts were off)
Had the fuel fiter replaced at 101k along with plugs.
Oil and filter done at 105k
Oil and fiter along with plugs at 110k
Oil and filter at 115k
I did have a pic of the skirts, but i can't find it on my PC......They are exactly the same as the factory skirts seen on the 2 door versions. (except are obviously for 4 door. Very rare to find 4 door factory skirts)
It does have TEIN coilovers.......however keep in mind that this has been my wifes' daily driver. Therefore, in order to ensure she had no problems entering driveways etc. we chose that height. It is not actually that high....a few of the pics have been taken from on the ground.
Plenty of adjustment left in the susp though if you want to slam it.
You can have the side skirts for $16,500.......i will even throw in a free skyline :P
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
