An interesting (but old) article for when Autocar tried to meet the production car lap records for the Nurburgring.
They took:
Caterham Superlight R500
Nissan Skyline GT-R (probably an R33)
Porsche 911 Carrera
RUF CTR II
Our goal could scarcely be more simple. We want to break the production car lap record for the famous old 12.95-mile Nurburgring. Currently it stands at 7min 59sec, set by a Nissan Skyline GTR in 1995. But given that the Skyline set the time during its development stage and was free of the speed limiter that prevents UK versions from doing more than 156mph, we can no longer count it as the true production car record holder. Especially as it's far from clear how much turbo boost the GTR was running during the lap, or how much tweaking the rear-wheel steer system had undergone.
So for these reasons and more, the standard production car lap record will no longer belong to the Skyline after this event; it will instead hold the record for a modified road car. Unless, of course, the unchipped, unfettled GTR that colleague Allan Muir is due to arrive in tomorrow can match, or perhaps better, that 7min 59sec time...
Source
https://www.sau.com.au/forums/topic/94417-autocar-on-the-nurburgring/
"Recently, Autocar magazine performed a test in Nurburgring track with this car against Porsche new 911 Carrera (300hp), Ruf 911 CTR2 (520hp) and Nissan Skyline GTR (280hp, 4wd, 4ws), the lap time is amazingly found as follows :
Caterham Superlight R .......... 8 min 6.2 sec
Ruf 911 CTR2 ....................... 8 min 15.0 sec
Nissan Skyline GTR .............. 8 min 28.1 sec
Porsche 911 Carrera ............. 8 min 38.4 sec
Benefited by the light weight and superbly balanced chassis, the Superlight R ran considerably faster than others in bends, although it lost a lot of time in fighting with drag in straights. Road tester found it handles very much better than others, it is virtually a racing car.
Nurburgring is usually regarded as the best place to test a car's real world performance - it has high speed straights as well as a hundred bends with different speeds. The Superlight R broke the track record for non-modified road car, so, maybe we can call it "the fastest car in the world". Hard to accept ? Ferrari F50, McLaren F1, Nismo Skyline 400R and Porsche 911 GT1 (this is really a racing car!) might be faster, but until they are tested in Nurburgring, the Caterham still remains to be the King."
Interesting Nurburgring reading....
Edited by Beeble
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
