My Yokahama AO32's had worn out so I went looking for a new tyre.As I drive my GTR everyday,R compound were wearing out quick.I decided to try the new RT 615's from Falken,at $330 a tyre for 255/40/17,they were cheaper than SO3's.They are not a true R compound but have thick sidewalls,aggresive tread pattern and brilliant grip,apparently I was the second guy to get them in Vic,someone else has a set on an STI.
Very impressed with grip level,have not tracked them yet,wont get a chance as I have some LMGT4's with RE55's waiting on the docks for me.
https://www.sau.com.au/forums/topic/94420-falken-azenis-rt-615/
Will be interesting to see how they cope with a track day. As a street tyre they should be awesome.
It will also be interesting to see where Falken heads in the future with their tyres since their parent company ( Ohtsu ) has been bought out by Sumitomo.
I am going to get the RT 615's as soon as Tempe Tyres get them in stock next month, they have been out in the states for a little while and I have only been reading lots of good things about them. Tempe said that they would cost me $280 a tyre for a 255/40/18.
m&m - how soft is the rubber? I realise it's not going to be quite as tacky as the Comp-Rs you've run in the past, but relative to your regular streeters how are they?
I'm up for new tyres in the not-too-distant future, and I want something sporty, but tyre life is a bigger factor since I'll have rims for Comp-Rs.
It seems my new wheels are delayed, so I'll have more time to wait for you to drive them around and let us know what the wear rates are. ;-)
I am very interested in them (I ran RT215s for a while and loved everything but the fact that they were wearing the tread depth indicators at 11,000km) but I'll have to see how they cope as a commuter tyre.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
