gdogzgtr Posted November 10, 2005 Share Posted November 10, 2005 I have just bought a 95 r33 gtr. It has just posted 310 kw @ the wheels. It has 2 steel plated ball bearing turbo's running 20 psi. Upgrded intercooler and piping. Adjustable hks cam gears 3.5 inch Exhaust going straight through cat. twin sports air filters Electronic boost controller Aftermarket E.C.U air flow meter hks sports cluth and fly wheel injectors and fuel pump. Sports suspenion and 19x10 mags. I would expect on a cold night with octane booster about 325-330 at the wheels. What 0-100 km times and 1/4 times would this be possible of. I would never take it to the drags but just want to know for my own interest. I was told it was possible for high 10's and just under 4 sec 0-100. Does this sound about right? Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/ Share on other sites More sharing options...
[HOTNXR] Posted November 10, 2005 Share Posted November 10, 2005 why wouldnt you take it to the track, sounds like its built for it Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1705145 Share on other sites More sharing options...
gdogzgtr Posted November 10, 2005 Author Share Posted November 10, 2005 why wouldnt you take it to the track, sounds like its built for it <{POST_SNAPBACK}> Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1705149 Share on other sites More sharing options...
ECR033 Posted November 11, 2005 Share Posted November 11, 2005 I very much doubt it would do high 10's with 310awkw to be honest. More likely to do high 11's to flat 12's with that sort of power... Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1705598 Share on other sites More sharing options...
marchGTR Posted November 11, 2005 Share Posted November 11, 2005 flat 12's??? you can do that with standard turbos. I would say if your pushing 320-330 rwkw and have a decent clutch you should get mid to low 11's and 0-100 in under 4 seconds. best way to find out is to take it to the strip! Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1705673 Share on other sites More sharing options...
Tommyk Posted November 11, 2005 Share Posted November 11, 2005 i reckon with that power you will do mid 11's. Depending very much on what dyno you put that power out on. 0-100 definitely in under 4 seconds Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1705773 Share on other sites More sharing options...
SKY031 Posted November 11, 2005 Share Posted November 11, 2005 An extra 20kw just from using octane booster? I'd pay to see that. Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1706577 Share on other sites More sharing options...
mazgtr Posted November 11, 2005 Share Posted November 11, 2005 (edited) I know of a R33 GTR with 285kw at the wheels that has done a 11.8 @ 118MPH. So id guess you would be looking at a 11.2-11.6 pass at about 120-124mph. You would need to post something like a 1.6-1.7sec 60foot time though. 0-100KM/PH would be in the 3.5-4.0sec area, depending on launch. About the lowest power for a 10sec pass ive seen, was a stripped out R32 GTR with a dog box and HKS-2540'S that ran a high 10sec pass with 358awkw... it needed a 1.51sec 60foot to do it though!!! If you've just got steel wheeled turbo's, and allready need 20psi to post 310kw at the wheels, then without a rebuild of the engine, or c16/avgas, you wont be able to run much more boost than what you are allready. Sounds like you have N1 turbo's fitted. No GTR with N1's is gonna have enough power to run a 10sec pass IMO. Edited November 11, 2005 by mazgtr Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1706849 Share on other sites More sharing options...
gdogzgtr Posted November 11, 2005 Author Share Posted November 11, 2005 (edited) [Thanks guys for all your responses. I would be more than happy with 11.2-11.6 1/4 mile time. I don't see myself taking it to the track any time soon though. I just wanted it set up for maximum accelaration and quickest 0-100 times just for every day driving to have the huge power when I want it off the mark to say goodbye at the lights etc. If I can run close to 3.5 0-100 I am happy with the results. I know it is set up for turbo's to kick is asap which is about 2900 rpm and has already 200+ @wheels by 4000 rpm and just keeps going. All up I have spent about $8500 for the mods, since it already had cat back exhaust, intercooler upgrade, suspenion and mags when I bought it. It's not a V-SPEC model done under 35,000kms. Is $45,000 on road a decent price for this car with such low km's and such mods. Including full black re-spray and sterio system and new clutch plates on top of the 8500. Anyway I still haven't even driven it yet or being in a gtr let alone a modified one. I hope its as good as everyone says and the good thing is my misses can drive a manual. What a shame. Just one more question for you guys with GTR'S dyno is the power at all 4 wheels or does it revert to only rear wheels on dyno? Edited November 11, 2005 by gdogzgtr Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1707456 Share on other sites More sharing options...
IOWNU Posted November 12, 2005 Share Posted November 12, 2005 [Thanks guys for all your responses. I would be more than happy with 11.2-11.6 1/4 mile time. I don't see myself taking it to the track any time soon though. I just wanted it set up for maximum accelaration and quickest 0-100 times just for every day driving to have the huge power when I want it off the mark to say goodbye at the lights etc. If I can run close to 3.5 0-100 I am happy with the results. I know it is set up for turbo's to kick is asap which is about 2900 rpm and has already 200+ @wheels by 4000 rpm and just keeps going. All up I have spent about $8500 for the mods, since it already had cat back exhaust, intercooler upgrade, suspenion and mags when I bought it. It's not a V-SPEC model done under 35,000kms. Is $45,000 on road a decent price for this car with such low km's and such mods. Including full black re-spray and sterio system and new clutch plates on top of the 8500. Anyway I still haven't even driven it yet or being in a gtr let alone a modified one. I hope its as good as everyone says and the good thing is my misses can drive a manual. What a shame. Just one more question for you guys with GTR'S dyno is the power at all 4 wheels or does it revert to only rear wheels on dyno? <{POST_SNAPBACK}> awkw. So all wheels. Haha I hope you have experience with modified cars, coz if you haven't this thing is going to be lethal in your hands! Take it easy for a while until you get used to your machine. Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1708147 Share on other sites More sharing options...
gdogzgtr Posted November 12, 2005 Author Share Posted November 12, 2005 (edited) [i've only had a TT Soarer and my misses has a TT supra which has 220 @ rear wheels. I will take it easy for a while for sure. One thing I have over most of you guys thiugh is I have done a 2 week extreme drivers course due to my job as a cop. Please don't hate me now I don't pick on Jap imports just when people have BOV that can be heard miles away or drive like a dick head we pull them over. Well that's in victoria I can't speak for other states and I can't speak for Traffic units either. Generally the most we can do is EPA the cars due to open air filters and BOV otherwise you are left pretty much alone. Thanks again for your response. Also in repsonse to earlier saying 20 kw gain form octane boost. It's not just the booster a dyno is the equilivent as a 35 deg day as lack of cool air as only fan blowing. If your doing 80km/h plus and it's a cold night you would get that improved 5% gain. Edited November 12, 2005 by gdogzgtr Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1708252 Share on other sites More sharing options...
IOWNU Posted November 12, 2005 Share Posted November 12, 2005 You're a cop hey? The import drivers worst enemy....joke, joke. It's cool how u don't pull imports over for no reason, which is what a lot fo cops do. Also find it interesting, that your car is defectable! LoL. Nah that's cool, I hope you stay on the forums and contribute to the Victoria section about laws/defects n stuff, coz it comes up a lot.....e.g "Are my pedals defectable, Are abc, or xyz allowed etc etc." Always good to hear inside knowledge. Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1708270 Share on other sites More sharing options...
gdogzgtr Posted November 15, 2005 Author Share Posted November 15, 2005 (edited) No worries. Anyone with questions on what's legal or defecable in victoria I will find out. There is no point spending good money to do up cars just to find out that it's illegal and you have to remove it or your car is unroadworthy. The most obvious things are loud exhausts, open air filters in engine bay and BOV which are all EPA issues. Edited November 15, 2005 by gdogzgtr Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1719809 Share on other sites More sharing options...
Drift R Posted November 16, 2005 Share Posted November 16, 2005 Fast and not much time!!!!! Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1721997 Share on other sites More sharing options...
croat Posted November 16, 2005 Share Posted November 16, 2005 mid to high 11's Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1722106 Share on other sites More sharing options...
NXTIME Posted November 16, 2005 Share Posted November 16, 2005 11.5-11.6@118-120MPH. Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1722313 Share on other sites More sharing options...
Big Rizza Posted November 17, 2005 Share Posted November 17, 2005 I reckon you should give it a run at the drags and find out! If you are too timid to drive it yourself (don't feel bad - that is a serious machine you have on your hands!) I'm sure there are plenty of friendly SAU members that would be willing to donate their time and run your car into the 11's for you Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1724944 Share on other sites More sharing options...
elGTR Posted November 18, 2005 Share Posted November 18, 2005 u should go to the creek and try it out, but don't expect getting 11s, I seen a fair few r32 gtrs with similar power output and the best they can do is flat 12s to 11.9 using micky tompsoms, mind you r32 is lighter than your car. Link to comment https://www.sau.com.au/forums/topic/94444-what-performance-times-should-i-expect/#findComment-1727441 Share on other sites More sharing options...
