This thread was started some time ago but read till end for follow up.
I here this expression frequently, some times in different context .
What does this mean exactly please?
How do you do it?
Why is super gromet style metal head gasket not sufficient? Or is it. <_<
An O ringed block will have a groove machined around each bore and a steel ring pressed into the groove. This will apply significantly more pressure to the gasket to prevent it blowing out under higher internal combustion pressures.
It is often accompanied by a matching groove in the head to further trap the gasket. Block O ring (if yoou are getting machining done) costs less than a metal gasket including the OEM gasket.
Wouldn't mind a wiki set up with technical terms like these.. great description GTRGeoff wasn't too sure of it myself..
Good idea :) Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
Good idea :( Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
What do you mean woeful?
There is nothing wrong with the search functions of this forum.
I use it so often and within 5 mins tops ive found what i was looking for, or enough information to make more questions.
Well make one yourself, maintain it yourself and submit it to the Admin
(i guess thats where the idea stops eh?)
Here's a link to a wiki that i was playing around with a while ago, dont have a lot of spare time at the moment though. If we can get enough useful info on here i'll register a proper domain name for it. Most of the info can be cut and pasted from other places on the net.
Skyline Wiki
This is not something for backyard mechanics, but a specialised engine machine shop will have no problems sourcing and fitting.
So is it better than a quality metal grommet style gasket or simply cheaper because one can use a cheaper gasket ?
I assume that one could not use a metal gasket if it hasbeen O ringed?
Skyline Wiki
Fatal error: Call to undefined function: getspecial() in /home/content/b/3/3/b33st/html/wiki/index.php on line 97
:lol:
If you wanna talk about setting something up, im more than willing to help with it all, simple enough to do id imagine.
Just gotta have the interest.
People use both, as posted above, but it depends on your power requirements.
The gaskets ability to hold pressure is the combination of its own structural strength at its weakest point, the clamping pressure of the head and head bolts, the evenness of the clamping pressure and any ancilliary aids to retention such as O rings or W rings. I've used an RB30 gasket modified to fit the RB25 at a time when RB25 parts were scarce and I had to move the car from Canberra to Melbourne and eventually it just pushed the gasket sideways into the water gallery. Blowing the head gasket could be from displacement, warping of the head, corrosion/poor preparation or a combination of those. The rings help prevent displacement.
Edit: as for is it better than the super grommet gasket, that is using stock gasket and O ring, I don't know. You would have to be producing some massive power for it to have to need better, and so cost would be little inconvenience and you would use the best of everything.
Thanks  for your oppinion Geoff,
i understandall what you said . My main piont and question is that many people use the term O ringedblock as if it is something super special  where i now see it as simply an cheaper alternative( in the long run) than an expensive quality gromet style aftermarket head gasket.
I will run with my Tommie super grommet and new ARP studs for now.
Thank you all for yor input.
Dave, A quality metal head gasket is upto just about anything you want to thro at it with most big power cars using them but the Oring adds that much more reliability in massive boost cars tuned to the limit like you plan for yours. When using an Oring on a metal head gasket it can take days to settle needing to be retensioned a few times before startup and then retension after its been run.Many 1000+hp cars run the metal gasket alone without trouble but at about $130 to Oring it wont add much to a major buildup and does seem to help if you overheat your engine and leaking after overheating seems to be the only weakness of metal gaskets.
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
