As for shifting, I've got a C's short shifter, and it's great.
It's reduced the throw a LOT, and you can actually beat the synchros if you rip the gearstick hard enough.
What that actually means, is that you can move the gearstick faster than the gearbox can mechanically change gears... So if you slow it down a touch, you can actually find the perfect speed to shift gears, so that you're shifting as fast as the gearbox can mechanically shift...
Does that make sense?
here i was wondering how the hell you got that with stock turbo like rev210 is trying to get to... feel sheepish now.
That's a bril 60ft time for that amount of power mate.
If i can do that once i get boosted i'll faint.
lol
  Quote
lol
hehehehehe... Yeah, unfortunately with RWDs, the more power you have, the worse power progression gets, and the harder it is to get a clean launch ;)
I could hit 2.0 60 footers all day with my other stock R33, but this one is a LOT harder to launch ;)
  Quote
mmm... not really :looney:
mine has a quick/short shifter in it too i know that ;)
but when you say as fast as the box, is that why i would get a crunch between 1st-2nd if i yank down mega hard/mega quick ?
cause that what happens sometimes !
goes in though so that means the clutch is in (doesn't it?)
As i've tried no clutch and it's impossible to get in
Hmmm okay.
Forget the shifter. The gearset in the gearbox and the synchros can only mechanically change gears so fast, right? Like you can't expect the gearbox to change gears in 0.001 seconds, it has a mechanical limit on how fast it will actually change from 1st or 2nd. If you try and get it to change gears faster than that, it will beat the synchros and CRUNCH.
What you're actually doing is asking the gearbox to change gears faster than it physically possibly can. It's impossible, so the gears hit each other and make a God-awful crunch.
So what you have to do is slow down the shift a tiiiiiiny bit until you find the speed where you pull your gearlever at a speed so that you're shifting just a tiny bit slower than the mechanical limit of the gearbox.
The gearbox doesn't like 'overselection' either.
The shift forks won't help you if you are one of those people who drive around with one hand resting on the gearstick at all times.
After a drag/race session its a good idea to chuck the gearbox oil and diff oil also.
  Quote
Originally posted by rev210
I gotta show you bastards with the big turbos what a stockie can do.
LOL true.
but then i'm only working with 9psi, same power figure as you.
just different curve.
  Quote
If you're wondering why my terminal speed is a little low for that power, it's because I ran 100% street trim. Not one iota of weight reduction. I ran with FULL stereo, subwoofer, about 40kgs of sound deadening, spare tyre and all interior trim and seats.
I've ordered some 245/50/16 NT555Rs for the two R32 GTR rims I have... I could have gone for those 275/40/17s, but I thought I'd trade a little width for more sidewall... I hope I made the right decision.
ice180: Last time I went to the drags, I tried loading up using the handbrake, and I promptly snapped my right driveshaft clean in half ;) I ain't gonna try that again in a hurry, cos I felt like the biggest dickhead having to be towed off in front of everybody :(
Andrew,
Once again, the same as me - FULL road trim.
Driven on the strip EXACTLY as it is on the street. Spare & jack, stereo, all seats/trim, pump fuel, legal rubber, the lot. I even make a point of having a full tank (for weight over the rear). Not quite 50-60kg of stereo/sound deadening though.
Yep mate you made the right choice :) 245/50/16's are the better option, more sidewall & all. I only want 275/40/17's so it looks all nice with 17's front & back ;) Plus I'll use them on the street.
Breakages suck the big one :( I felt for you when I heard about the shaft failure. Good story to tell the kiddies though :(
I have a 100hp wet kit, quite literally, sitting next to me... but I can't use it, nor can I turn up the boost past 1.2 bar until I get my internals done :)
Dave,
A 10! I think I need you to drive the car for that to happen. Plus have the Nitto's on.
A small shot of Nitrous (50hp) to help off the line would be nice. But like Andrew, I won't be doing anything like that until the internals & injectors are upgraded.
Enrico,
On dry straight road I use to get w/spin in 1 & 2 (occasionally 3rd) at anything up to 110km/h. Suspension mods (including pineapples) & good quality rubber has made a HUGE difference! I still get w/spin if the tyres aren't warm but once they are it rarely catches me out.
my R31 puts 190 to ground.. and only just spins at the top of first (6000rpm+)... and will skate violently in second when i shift it hard and just chirps other gears.
and that's on 215's and fairly hard front/rear shocks/springs.
no pineapples or anything like that.
No grip problems for me.
    • Cheapest Jaycar one is only $65.
    • Probably best way would be using a proper dB / SPL meter lol Buy one and ship it from state to state to have a consistent test device lololol
    • Not electric car good of course, it's still just a crappy old ICE
    • Yeah, but the good news is that can all be tuned out...the V37 has excellent throttle response now, and with the tiny factory turbos is pretty quick without lag
    • I did change bodyshops. The most recent place was very fast. I think the trick is to have smaller, simpler jobs. A front end repaint and some (extensive) sideskirt and fender stuff is a 'small cash' job for them. It was expensive but 'worth' it purely cause: 1) They did everything great 2) They did everything fast Get what you pay for maybe? Pictured: Very stock looking car from my very old phone. I did realise that oncoming traffic would probably be like "Oh look at this guy, commuting around in a GTR!" (until they see the side profile). This is the sad state of my fender liners and front fitment with my current stock GTR sized wheels (18x9 +30) This is how the rear sits with a 25mm spacer. I say 25mm because it's actually a 20mm spacer sitting on the studs which are ~30-31mm, and the wheels have a ~5mm cutout. So... this is very not safe to drive. This is the other side.. .with a 22mm spacer. Yes, the studs are ~27mm. Yes they're different both sides. I spent a fair amount of time measuring. This was the old pod setup behind the box in the past. Old vs New Pod she tells you not to worry about:   Turns out I measured this pod filter pretty damn accurately which I was chuffed about. I went for a ~3hr drive for 'testing' reasons up into Healseville hills. Believe it or not, the induction noise is the same between small and large pod. I guess it has more to do whether a pod is *present* or not, and the diameter of the pipe. It does sound very decent in cabin though (and extremely 'smooth') - Though behind the car the exhaust noise is nonexistent now. So uh, it's all for the driver. I'm confident it has to be quieter than @Dose Pipe Sutututu's car. I should test it. Is there a way to do it with an app or something we can both agree on? (we are both very old men now competing for quietest car) I've texted Trent at Chequered to book in to see some before/after. I can now twist the pod entirely out of the engine bay on the dyno to really rule in/out any intake restrictions. And/or remove the pipe entirely which I will probably do for testing reasons. The logs show *maybe* a difference in ambient KPA vs Intake KPA at wot. But I'm talking the difference to -3/4 before to maybe -2/3 now. The tune is not wildly out or even changed at all. The only takeaway I have is the car is on 17% ethanol as it's still got the fuel from the dyno in it. It's plausible that that tune would have resulted in the car erring on the side of being too rich (it was) and right now it seems to be bang on perfect or within -0.5% either side of target. I was tempted to take it to a Drag day to see what MPH it would trap (and tune the car) but then I wouldn't have a number and a pretty line. I may do that after I re-hit the dyno, purely to go to LS1tech and shout about how their dynos are all very inaccurate while my low HP car traps the same MPH as cars with the same setup in the US, who make 375RWKW (supposedly). It was safe to say Mr Mamo was not really happy with me posting the results yet. So I owe it to at least try the intake thing for my own sake and not besmirch people who want to buy a similar USA heads and cam setup and get disgusted that they make lower HP than simple bolt-ons which can be up to the "330rwkw+" kw region over there - Which here equates to about 270kw. (and runs the same 115-118mph)
