  • 2 months later...
All things going right i am going to run a low 13 in my gf's S14 with ecu remap, 3"CES exhaust,pod filter&partion, 15psi boost,optimax or ultimate with octane booster!
Has run 13.75@102@willowbank (exhaust,pod&boost) but i am going to try retread slicks, ecu remap &tiny bit more boost plus it's auto!
4doorz from Queensland just ran a 12 in his black 4dr R33. It was a [email protected] with a 2.045 60ft time. Quite impressive considering the limited mods. Mods include FMIC, full 3in exhaust, Power FC, Pod filter with cold air box, 235/40 R18 Federal tyres at 25psi, DIY boost controller, Heavy Duty clutch. The rest is reportedly stock. Not a bad effort. I saw him run a 13.2 on the Wed night test and tune at Willowbank, then on the Saturday Test'n'Tune broke into the 12s. Not a bad effort. Not sure what boost he was running, he did tell me just can't remember.
Also ran [email protected], 1.988 60ft on the Saturday aswell.
I think a good result on such limited mods.
Geez the sau 1/4 times are a little slow! I would have though that with all the people on here someone would be doing a 11!
Don't get me wrong my sx only runs 13.75 but it's got stuff all mods. I mean I thought skylines were fast?? My mates auto 300zx with less mods than others in the list would be no3 on that list plus he ran more mph(116.5mph) with std turbos, std i/c's, std ecu other than speed cut removed & rev limiter 500rpm higher, 245/16 falken tyres grb & a few minor other mods. And this is in a heavy, unreliable, overheating piece of junk 300ZXTT !!!
You will find that their are alot more people in the 12's just that not everyone is aware of the thread or has PM'd me there details.
Also I think their is only 1 GTR that has his time posted. With afew more R's the times will drop into the 11-12's.
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Hi guys, a few have asked questions, which I will try and answer....
When we go to the circuit I stick on a set of R tyres, Yoko A0323R's to be precise. While I have the car jacked up to change the wheels over, I crank on 1.5 degrees more negative camber (total 2.5 degrees) on the front. I also add 1.5 degrees to the rear (total 1.5 degrees). We use the Whiteline camber adjusting bushes for this, real easy.
The stabiliser bars are also adjustable, we run full soft on the rear for drags and the middle setting for circuit. Front we don't change much, unless the circuit is slippery raining or super grippy. So we basically tune the balance (oversteer/understeer) with the front bar. This is done while the car is jacket up changing the wheels. We use the Whiteline blade adjustable stabilisers bars for this, real easy.
Our shocks have adjustable bump and rebound rates, so all I do is add a bit more bump on the rear shock for the circuit. Rear rebound rate stays the same for drag or circuit as does the front bump and rebound. You guessed it we do this while it is jacked up as well.
I used to change the rear springs to harder ones for the circuit, but once we got over 600 bhp the softer (drag springs) power down better (less oversteer) and the shocks take care of the rest.
If we want to drift, I just whack the rear stabiliser bar on full hard, don't add any rear neg camber and back the front bar off to full soft and it slides like a 180.
I know it sounds like a lot of work, but it only takes a couple of minutes extra per wheel over compared to just changing the tyres. Jacking it up and removing the wheels is always the hard work, shame not to do more while it is up there.
Hope that adds to the thread and answered a few questions.
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
