I run the same fan J.
I fitted mine (16" DC & thermal s/w) new ~1.5-2 yrs back. It keeps the temp's under control even in 40+C traffic no prob's.
Normal water temp is ~80'C
Have hit a max of 92'c on a 32'c day after hrs worth of dyno tuning runs (hotter in the dyno cell!).
Matt - sweet.. That's what I like to hear.
Rev - I had a good look at it yesterday, and I don't think I'll be able to keep the shroud :) But I'll do my best to try and keep it, even if I have to chop it a bit. I let you know how I go on the weekend.
J
Originally posted by rev210
Another mod I'll add to the list is replacing the flexi tube between the turbo and the afm, probably with a metal pipe. The factory pipe is quite restrictive.
Guys,
Yeah I lost the shroud in my thermo set-up. Hasn't been a problem for my car though. I do intend making a flashy new one (one day :rolleyes:) A few hard laps of a track may be a different story, but I'd be going for a bigger better radiator if I got into track racing.
Rev,
Flexi tube - Yep ditched that a while back too :D Nasty looking piece of gear. I run a completely new metal intake pipe (nil AFM & all) From turbo to filter is custom fabricated.
Much thinner than the standard clutch fan. Easier to fit nice big FMIC pipes across the engine bay (inlet & outlet on opposite side style) without fouling the bonnet or stock fan blades.
You need to wire the thermo in with a relay, fuse (30A) & thermal s/w. There's plenty of room in the fuse box to fit the extra relay & fuse.
Below is an old (poor quality) pic of my inlet piping. The blue silicon Samco hose section actually has piping most of the way through it (nil chance of sucking in!) but a small section is allowed to flex, then the adapter for the K&N is on the other side.
Rev210 your chase for 12's will be difficult with the stock turbo and impossible with the stock intercooler, I doubt 10psi will get you 12's. Delay the little mods like fans,pulleys and cam gears and get a large FMIC, with the SAFC and an increase in boost a 30rwkw+ gain should be seen, if your still short then try the little things but the intercooler must be your next mod.
I worked out if I can get a 1.9 60ft , 104mph is enough to get 12.9 should I not fall asleep changing gears. Actually if I got a 1.9 60ft my mph would be higher than 104 and the time probably lower.
then again 1.9 60ft is a little hard to do on 205's.
Originally posted by GTS-t VSPEC
Nice engine bay, I don't have the problems with the piping due to a different plenum, so hopefully that will make the fan even easier to install.
See'ya:burnout:
Thanks mate. I've tarted it up a bit more since that pic.
With a Greddy plenum (or any front mounted TB manifold) the piping will be easy :rolleyes:
Whatisname,
Yeah, I have the Greddy plenum, and it makes working on the car that much simpler, especially removing spark plugs.
rev, I think that a set of 235's or 245's would be good for you, would allow much harder launches.
See'ya:burnout:
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
