Ok, I started a new post here are pics of my car, over the last 15 months I have been doing so much to my car.....
GTR V-spec conversion
Everything has been done , just missing airbag and door trims, yep even done Brembo brakes............and Multi Function Display Screen
Ok, guys what do I do next, its too late to sell the car and buy a R34 GTR v-spec as ive poured in too much to it and there is no turning back....
Apexi Power FC
Apexi Exhaust
Boost Controller
Hyper (crap) intercooler (will change soon)
Look forward to you replies!!!
https://www.sau.com.au/forums/topic/94470-pics-of-my-car-gtt-gtr-r34/
  • Replies 133
Posted Images
Nice job and looks clean. To live up to its look I think you would at least need these mods: 3" turbo back exhaust, cold air box, FMIC, Power FC, bigger fuel pump, injectors, bleed valve/electronic boost controller @ 12psi then hiflow turbo. Not to make you feel bad but the money you spent on the conversion you could have got twice those mods :)
Car looks nice - just some things that dont sit well with me -
1. its not a GTR or a V spec so why use the badges.
2. if as you say everything has been done - wheres the rb26 - I would
think that would be one of the main things in converting a Gtt to a
GTR? Same goes for gearbox - 6 speed???
Car looks nice though - maybe dont worry about modding the rb25 and whack a rb26 in there....
Just my opinion though.
I had to work things out with wires, trace them and wire them up to the display. works with std gtt ecu and power fc
also , IMACUL8 I would have done the RB26 but at the time was hard to get hold of an engine, also its an everyday car, If I put a rb26 in there, im worried it will be too much stuffing around, also I brought a 99 NSX 8 months ago and am broke due to Payments on that
hmmmm interesting
woudl really like to hook up the display. So do all its functions work??
i wonder if you could do i diy on getting the display working with all the wires.
if you dont mind me asking how much did the display cost you??
I cant not put the badges on, its only missing the motor and box.
You never know I might do that next,
I think I have the right to put the badges on after all the work and money I put into it.
I use to own a R33 GTR v-spec.. dones that help?
sorry dude but have to agree with pnblight on this one....
Dont like the badging.......styling is all good but its NOT a GTR so yeah doesnt suit it.
But never the less its an awesome looking car...just curious as to how much it cost you to get the GTR guards ?
Im looking at phattening up my ride a little bit as well.....
Guards around 500 each for front and 1500 each for rear ( rears needed a inner guard.
Does anyone know of where I can find a RB26DETT from , a good one?
hot damn !!!! thats too much for me...rather spend that on engine internals or a bigger turbo....
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
