As the title suggests im curious to know about peoples experiences and/or opinions on a forward feed plenum on the RB25s.
Either a custom made one or a greddy one or an RB26 one adapted to suit.
Are all 3 essentially the same and do the hinder performance or do you gain performance ?
Ive heard many different arguments for both sides and would just like to get the opinions of people on here.
Also im very interested in peoples expereiences with forward feed plenums on the NEO RB25DET. If you have one, what style did you go for?
I originally wanted a greddy one...but apparently they do not make one for the neo type and they would have to use an R33 one and drill new threads in the cylinder head to make it fit.
which brings me to my next question....is it BAD to drill new threads in the cylinder head ?
cause it certainly SOUNDS bad.... :)
My next option short of a full custom job is to get one of them new adapater plates to make an RB26 plenum fit. If indeed this is truly a "bolt on" mod then would all the fittings and hoses etc fit on the rb26 plenum ?
Edited by shonen
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/
i currenlty am in the process of doing some flow testing for a rb25 plenum comparing stock to mine style, which have a foward facing tb.
it all depends on what you want to do with the car.
one of my rb30 plenums just helped a car make 780rwhp !!!
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1707200
hooray for the search :(
This is only a SMALL toe in the water with these threads
Draw your own conclusion, my feelings are in the below
http://www.skylinesaustralia.com/forums/in...89670&hl=plenum
http://www.skylinesaustralia.com/forums/in...68046&hl=plenum
http://www.skylinesaustralia.com/forums/in...25648&hl=plenum
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1707289
I don't see how the TCS is the problem. You can remove it any old time. All that will happen is that your slip and TCS lights will always be on in your dash.
The issue is all about fitting of bits like injectors, fuel rail and water lines. If no one is making one now then I guess you have to get something that just goes on the top half of the plenum.
(I may be confused but would you call the bottom half of the plenum the inlet manifold and the top half just the plenum?)
Maybe that bottom half could be cut about 5cm out from the head and some new thing fabricated for it. Will it work properly though?
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1708974
high-mount should pose no problem to piping using a stock item by any means.
Glad you raised that point as I would like to know what people think of that setup.
Ive only ever seen it done 2 ways.
1. The piping comes back up the same side and goes around the turbo one way or another.
Like this
or this
2. Piping comes up from where battery is and goes behind fan and goes over the rocker covers and practically does a u turn to connect to the stock intake.
sorry couldnt find a pic :lol:
With option 1 personally I think the cooler pipes are too close to the turbo and cant be too good for cooling properties.
option 2, too many bends in the cooler piping and once again coming close to the turbo....assuming a high mount setup of course.
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710132
i like the rb26 plenum idea but the cost is about the same or more than the greddy plenum
GTR Plenum $200-$300
URAS or Blitz Plenum adoptor plate $600-$700
then you need to have an aftermarket ecu and a few more bits, i have alook for the website for you which tells u what needs to be done to get it to fit
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710372
U thought about running the plenum cooloer pipe down the left side of the bay? As in coming out of plenum, 90 degree bend, runs parallel to turbo/motor, then 90 degree n goes across/inbetween front of motor n radiator.
Or there could be the option in sending it backwards straight of the plenum n down the left side, ledd bends that way
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710490
that was option 2 I was talking about...just didnt have a pic !!! :P
as I said earlier.....too many bends for my liking and really cluters up the engine bay...also comes just as close to the turbo as the first option.
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710664
hmm does anyone know where to get them from ???
I saw the ad in the latest Hpi but cant find anymore info on them...
the autobarn website is practically useless....
I already have a PFC.....so including labour this option could be done for around $1500.....last I checked greddy plenum was around the 2K mark...fitted.
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710670
so far i have only seen them sold on yahoo auction and jap website, i dont know anywhere in Australia that sells them you could try contacting nengun, im sure they can source it for you.
I was under the impression the greddy pleunm cost 1k or alittle be more for the kit (come with t.b and cable i think)
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710683
i dont believe there are sufficient gains to warrant the cost and crap you have to deal with to have it changed. we have seen numerous times $xyz-person has a $random-manufacturer plenum and they had issues with response and didnt make any more power. the $1000 cost does not justify the gains, and thats if you make any gains, many don't.
i dont believe shortening the pipework (as covered in previous post) will make a noticable differen as well. certainly if the pipework (length + volume) is %35 more then yes it will be worse but if you are talking re: past radiator vs using stock pipework then there probably isnt sufficient gains to be had, or noticable difference. certainly doesnt justify $1000 on a front plenum.
not a negative nancy would just be happier spending $1000 on something that had a high gain per $ than the front plenum
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710699
The reason for using a gtr plenum on the rb25, so to get more responsed (its not a power gain). Now i havnt seen anyone in australia uses the blitz/uras gtr/rb25 plenum adptor.
But somehow i think that there will be responsed gain or why else would Ken Nomura (R34 4dr d1 car) uses it, if it gave poor results compare to a stock plenum system?
just my 2cents
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710823
because they believe marking crap or have money to burn?
there may be some gains by using individual throttle bodies but $1000+ worth? surely you can get more power gains overall by spending the $1000 better ways
https://www.sau.com.au/forums/topic/94481-plenums-on-rb25/#findComment-1710872
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
