I Have All This Sick Leet Gear For Sale!
By DraftySquash · Posted
Wanted to clean the film behind the triple gauge so the lights show through better. Progress so far…. -
Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage. Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination. The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too. Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
