I have sold my standard GTR fuel pump from my R32 GTR and bought a factory R32 GTSt fuel pump, and an aeromotive A1000 external pump ( this one ). I need to shift my car to the other side of town, but i cant get a surge tank for 2-3 weeks. Will my car run on just the GTSt fuel pump? Or will it run with low fuel pressure and cause my car to run lean? And an external fuel pump must have a surge tank/swirl pot, correct?
Thanks guys!!
Adam.
https://www.sau.com.au/forums/topic/94510-gtst-fuel-pump-in-gtr/
I do believe it will run fine, provided you arent maxing out the gts-t pump. If you could keep it off boost ~4-5% injector duty cycle, then i dont think you would have any problems
Ah thats awesome, thats what i thought too, just needed another opinion! thanks!
Unless you plan to do a lot of circuit work / drag racing I see no need for a surge tank.
You can even get away without having one as long as you keep your fuel tank full.
I doubt you'll have any fuelling problems - it anything it will probably run rich - I know of guys that run a standard r31 non turbo pump in tank and use a bosch external in high hosepower applications. Your external will give you plenty of fuel pressure.
These are the specs of your pump below, now why are you buying one of these at $290 US when you can buy a bosh or walbro pump that will give you close to the same sort of power I think the walbro in tank supports up to around 450kw (could be wrong on that figure) sorry to be so negative but it just seems like there is a lot of better options locally and for less money.
Specs:-
For carbureted powerplants making up to 1200 HP and fuel injected engines:
up to 700 HP - forced air induction
up to 1000 HP - naturally aspirated
up to 1200 HP - carbureted systems at the track, on the street, and in the water.
  • 3 weeks later...
Yea ill probably just put it in line without a fuel cell for the mean time.
havent got a fuel cell yet matt, where should i get one from? maybe we should get someone to make up 2 for us (1 each!) :)
Yea if i were buying a fuel pump id buy a walbro or bosch, but i got this real cheap, so im going tyo use it.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
