  • Replies 83
They are due to run out next week and have supplies arriving the week after. My dad works at the refinery....If worst comes to worst you can still use the premium unleaded (shell or bp), just don't run on high boost and don't thrash the car.....Simple.
Ok, got an update today. Shell & BP are running low on premium also. But they expect that the bit that failed will be fixed and up and running again by Wednesday. I don't think it was the compressor but it started with a C. Lol. Sorry I don't know much about machines and that kind of thing.
I asked how long it would take till we had ultimate back at the bowser and he said 1 or 2 days after they get it running. So if all goes to plan, we will have ultimate on or before the weekend. If all does not go to plan, then they have the supplies which are already on the way. So it shouldn't be too much longer *fingers crossed* all goes to plan...
from abc.net.au
BP defends delay in going public over fuel shortage
As reserves of premium unleaded fuel dry up in Western Australia, petrol
producer BP has defended its decision to delay telling motorists about
the problem.
BP supplies premium unleaded to more than 600 retailers state-wide but
has been unable to produce the fuel since a mechanical fault occurred at
its Kwinana refinery.
The breakdown occurred two weeks ago but BP only went public yesterday.
Company spokesman Peter Metcalfe says service stations are already
starting to run out.
"There's around about a dozen BP sites have run out completely and I
think in all honesty that situation is likely to grow," he said.
Mr Metcalfe has defended the time it took to alert the motoring public.
He says the company was not sure at first whether it had an issue and,
once the scale of the problem was realised, it tried unsuccessfully to
source additional supplies from overseas.
Motorists who can are being urged to switch to regular unleaded until
supplies are restored - hopefully - by late this month.
The Motor Trade Association says the fuel shortage shows there is a need
to set up fuel reserves in Western Australia.
The executive director of the association, Peter Fitzpatrick, says the
Government should stockpile fuel to help deal with any future shortages.
"We are very exposed with one refinery where you can have it break down
or get some contamination, and I think that the Government, and I've
asked them to do it, to look at it before, should have a strategic
reserve set aside for just this sort of contingency," he said.
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
