  • Replies 83
They are due to run out next week and have supplies arriving the week after. My dad works at the refinery....If worst comes to worst you can still use the premium unleaded (shell or bp), just don't run on high boost and don't thrash the car.....Simple.
Ok, got an update today. Shell & BP are running low on premium also. But they expect that the bit that failed will be fixed and up and running again by Wednesday. I don't think it was the compressor but it started with a C. Lol. Sorry I don't know much about machines and that kind of thing.
I asked how long it would take till we had ultimate back at the bowser and he said 1 or 2 days after they get it running. So if all goes to plan, we will have ultimate on or before the weekend. If all does not go to plan, then they have the supplies which are already on the way. So it shouldn't be too much longer *fingers crossed* all goes to plan...
from abc.net.au
BP defends delay in going public over fuel shortage
As reserves of premium unleaded fuel dry up in Western Australia, petrol
producer BP has defended its decision to delay telling motorists about
the problem.
BP supplies premium unleaded to more than 600 retailers state-wide but
has been unable to produce the fuel since a mechanical fault occurred at
its Kwinana refinery.
The breakdown occurred two weeks ago but BP only went public yesterday.
Company spokesman Peter Metcalfe says service stations are already
starting to run out.
"There's around about a dozen BP sites have run out completely and I
think in all honesty that situation is likely to grow," he said.
Mr Metcalfe has defended the time it took to alert the motoring public.
He says the company was not sure at first whether it had an issue and,
once the scale of the problem was realised, it tried unsuccessfully to
source additional supplies from overseas.
Motorists who can are being urged to switch to regular unleaded until
supplies are restored - hopefully - by late this month.
The Motor Trade Association says the fuel shortage shows there is a need
to set up fuel reserves in Western Australia.
The executive director of the association, Peter Fitzpatrick, says the
Government should stockpile fuel to help deal with any future shortages.
"We are very exposed with one refinery where you can have it break down
or get some contamination, and I think that the Government, and I've
asked them to do it, to look at it before, should have a strategic
reserve set aside for just this sort of contingency," he said.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
