Well i have recentrly purchased a project car, so i think it might be best if the cefiro goes
1988 Nissan Cefiro A31
R33 Series 2 RB25DET
5spd Gearbox from R33
3"dump/front pipe
3" Titanium Cat Back
Trust FMIC
Trust Type R BOV
FET turbo Timer
Nismo 5 puk Clutch
Nismo(old school) Locked Diff (recently been reshimed, tight as)
5 Stud Conversion
R33 Brakes Front and Rear
Tein HR Coilovers with camber tops front, solid top hats rear
Cusco Adjustable Castor Arms
Adjustable Rear Camber Arms
Adjustable Rear traction Arms
Adjustable Rear Toe Arms
Front Strut Brace
Rear Subframe Alloy Bush Kit
6-Point Bolt In Roll Cage, Front Half Paded
Sparco Race Seat
4-Point Sparco Harness
Momo Steering Wheel
Razo Shift Knob
Full Bodykit
MP3 Player
Kenwood Front Speakers
Registered For 6months
Oil Change done ever 5000kms
Front 17"x8" with P6000 tyres 75%
Rear 17"x9" with Bridgestone SO3 70%
This car handles very well.
Price with mods listed $18K
Price is subject to negotiation.
Car is located in perth
email me for more info
[email protected]
https://www.sau.com.au/forums/topic/94534-fs-cefiro-ready-for-drift/
offers around $15K would get the following mods
Trust FMIC
Trust Type R BOV
FET turbo Timer
Nismo 5 puk Clutch
Nissan Standard LSD
5 Stud Conversion
Front Strut Brace
Sparco Race Seat
Momo Steering Wheel
Razo Shift Knob
Full Bodykit
Edited by StilledCefiro
Just to TRY and help a fellow ceffy owner out. As much as red is an aftermarket colour, the only other red cef I've ever seen is mine. So you would be buying a rare car, with an even rarer colour.
They are good mods for the price. Someone snap it up!@
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
