The subwoofer I have has a built in amp.
If I buy an amp to power my speakers, how do I wire that up?
Can I just split the power and the REM and connect one to the sub and one to the amp, or do I need to run two power cables, and two REM cables?
Thanks.
https://www.sau.com.au/forums/topic/94561-installing-2-amplifiers/
really depends on how much power you want to run and what sort of power cable you have running, what are you looking at getting put in and what size is the amp you are looking at and the sub you have?
the sub is a little 8" in a tube
like some kinda bazooka sub
its not very powerful
the amp im looking at getting will probably be 400-500 watts
so the REM cable doesn't matter much? it's more the gauge of the power cable?
what happens with the fuse as well?
yeah, the REM cable is just the remote wire from the head unit telling the amps to turn on when the head unit is on, the power wire is the one you need to make sure will run enough power through it...
what size fuse is it and what is the gauge of the power wire?
if the wiring was some sort of amp wiring kit package thing or similar then the fuse etc should be okay to run it, something like 8gauge or higher...mine runs 4 gauge with a 60amp fuse at the front...
Yeah, I might just buy a new wiring kit for a high powered amp I guess.
I'm not sure what gauge the wires are, it's red, that's all I know :)
I might just get JB to install it when they do the alarm I guess
the easiest way to wire up the two amps is to run one wire which is at least 6 but better to be 8 gauge from the battery + to your preferable 60 amp fuse and then continue that thicker wire into the cabin and wire it into a power splitting box, you can get stackes of em from jb or whatever they just a metal conductive box with plasic around it and u screw the wires in, you can put the one feed from the +12 into it and then 2 wires out, these wires dont have to be as thick as the original wire but i would suggest at least 6 gauge, wire these two +12 wires into your different amps, then run sepparate ground wires going to different spots for both the amps, and with the REM (remote) wire run it from the headunit into the first amp and then connect it up to the 2nd amp, it doesnt matter isf it runs in parrallel or series it only used to tell the amps to turn on, with four rca's if u have frt rear and sub out, run the frt n rear out's to the amp with the speekers and the sub out to the sub ect if not use splitters, hopefully this helps you AND SAVES SOME MONEY
i run two amps, i have one cable for each amp coming from the battery, different size and an appropriate fuse for each amp.
for the earths i have used the same size as the power cable back to the battery.
i dont like the splitter boxes because if you have a system that draws a fair amount of current, its good to have good joins between cables, such as clamping them down in the battery terminals (proper ones not the original jap ones!) whereas the splitter boxes only have a small contact area and dont clamp down very well.
if you have a smaller system(sounds like u have) it wont matter so splitter box will make things a bit easier :P
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
