Hey guys,
I've got an 89 GTR. Mechanically sound and stock except for an AVC-R and cat back exaust.
Problem is that the boost controller is set to run 1 bar and the boost solenoid is pulsing hard at 90% duty cycle to get the boost to ramp up faster. Its not ramping hard enough, it does hit 1 bar right at the top of the rpm range (6600 or so). I've been advised to block off the blow off valve return pipe to see if the valves are leaking (remember they are 16 years old). Wastegate actuators have been checked and cleared.
Has anyone experienced this problem and any ideas as to what may be the cause??
perhaps one turbo is tired. or about to explode.
they are standard ones are they.
as a referance mines stock and reaches full boost (13 pounds ) at around 3500 loaded up.
6600 is way to late. id check te cat for blockages etc. apart from the obvious air leak checks thats about all i can sugest . sory
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
