Hey guys did a search and cant seem to find much on this for my car.
Basically my car is a 88 Silhouette with RB25/30 T78 turbo and a few other things running 9psi.
Im looking at some time early next year, january/febuary to upgrade my brakes to handle to power it should be putting down a little better. At the moment its completely stock. I would like to upgrade the rotors aswell as calipers. Im just looking for some info at this point in time in what would be a good upgrade, i'm hoping the car will be putting down 450-500rwhp before too long and i know the standard brakes will not be able to pull me up in time.
Would like to spend a few grand, Dont want to go to crazy though.
Any help will be greatly appreciated.
Ben
https://www.sau.com.au/forums/topic/94608-brake-upgrade/
best bet is talk to slip... he ran 32 gtst running gear.
alot of custom work and suspension issues.
a guy down at BDA (name starts with T) helped him out.
i have also done turbo caliper/rotor upgrades with custom dba slotted rotors for 4 stud applications.
https://www.sau.com.au/forums/topic/94608-brake-upgrade/#findComment-1708611
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
