  • Replies 49
got the winfield from gamesworld in rockingham it was $129 that was 15 months ago.
got the calsonic from Triking Stamps and Models (hey st Perth Wesley arcade) $99
yeah the calsonic is the 100th edition model from kyosho
the winfield is a kyosho special aswell.
NeoNode
Love it :D
Jon R33
answered above
BoOsTeD_RB26
above and theres a couple more i've seen. the calsonic in a lighter blue, and a black and green stripped one (only seen on a website and they were sold out.)
INASNT
i got 3 gtrs the ones pictures plus i got 12 others
Corrolla WRC rally Aus version
Lambougini Diablo SV
Lambougini Countach
Calloway C12
BMW M3
BMW Z3
Mercedes SLK Kompressor
Ferrari 360 Mondena
Ferrari Testarossa
Jaguar XK 180
Toyota Supra MKIV (bloody hard to find at the time seen more around now)
and a Team Exxon Racing Dodge Viper
hako
yeah i doubt its one of 10 maybe one of 10 he had
NeoNode
Love it :D
Jon R33
answered above
BoOsTeD_RB26
INASNT
Lambougini Countach
Calloway C12
BMW M3
BMW Z3
Ferrari 360 Mondena
Ferrari Testarossa
Jaguar XK 180
hako
nice!
now dont u wish u had a warehouse with all those real cars in there???:eek:
Originally posted by EnricoPalazzo
I have the frenetic model Skyline like someone said. Ive had it for like 6 months and its still in pieces after i took it apart and tried to get the Stage 3 turbo kit to work
Dammit
If only i could be stuffed fixing it.
Ahwell someday.
haha were in the same boat... did you get stage2 to work?
i got that working then went to put in stage3 and gave up.
Shaun
Was just checking out ebay and they have a Biante (???) model Winfield R32 GTR in box with brochures and stuff for $305 and the bids are still going up
They also got those real small RC Skylines too
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
