Whats up guys. Im moving overseas soon and i'll be getting a R32 gtst there.
There are no major rules against modifying like here in OZ so i just wanted to know what mods i can get done to the car...the catch being that there are no dyno facilities there so when should i stop modifying the engine ( tuning problems with bigger turbo's, power fc, etc)
Can u tell me what turbo and computer will be best for my situation.
Ive got suspension, etc covered but i dont wanna be stuck with just a fmic, boost controller, etc.
My goal is around 200 rwkw ( i dont exactly know how i will measure this :D
Do u think its possible cos there are a few fast cars there such as BMW M3 Coupe, R34 GTR to name a few and i wanna keep up with them( i know its a big ask ;)
Thanks for your time and consideration guys.
cheers
Edited by 2BLAK
https://www.sau.com.au/forums/topic/94618-suggestions-and-opinions-wanted/
If it was me I'd be doing a crash course in the pfc, microtech or many others, with an exhaust sensor you can do a tune with 2 ppl while driving.
For 200kw on my rb25 i have pod, 3" turbo back, intercooler, 1bar, fuel pump/reg, and microtech. Without the microtech I had lots less kw but was running shite.
Duh slaps forehead. You can do all your mods then get a chip custom made for them so whayever you do theres some one out there who can do it for you.
250-260rwkw:
3" dump pipe / front pipe combo
3" hiflow cat
3" cat back exhaust
electronic boost controller
550cc injectors
apexi powerfc
gtr fuel pump
gtr front mount intercooler
hks gt-rs turbocharger
tomei 260 poncams
z32 airflow meter
heavy duty clutch
good tyres
good driver
200rwkw:
3" hiflow cat
3" cat back exhaust
apexi powerfc
gtr fuel pump
good tyres
good driver
youll still need a good tuner and a good dyno to make either combo work
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
