I have a GTS-4 and i also had this prob but it was a fairly violent shake. This was because i needed two new rears and a mate fitted ones that were slightly smaller than the old ones. as soon as i hit about 3G+ the car would shake, because it thinks that the rears are spinning at different speed to front. i just drove around in RWD for a few weeks then threw the same tyres on the front and problem solved.
P.S. i have fitted a switch running from the 4WD/ABS fuse so that i can drive in RWD or 4WD wheather i need a quick launch or a little slide. I suggest gettin a switch hooked up. and its a piece of piss. :O
:D nicee! i should do that too! just a question. on the gtr the 4wd fuse is also the heater fuse. does it mean if i pull it out i wont get heater? good thing its summer! i might need to drive around in rwd too until i get new rears.
  • 3 weeks later...
Just a bit of advice if anyone else has this problem, it turns out that it was just the uneven tyres at the front and rears. The problem is gone after i got new rims! So before you do all the other stuff, check to see if the tyre wear is even at the front and back.
Cheers
Phil
  • 9 years later...
Ok, now i have a bit more time,
We had to replace a broken CV boot on the right hand side, at the same time it was time for a little investigation into the problem, as soon as the CV was off the car the 2 guys in the workshop (Simon and Nathan) saw the problem.
There are 3 symetrical "dents" in the end of the CV housing from the roller part (sorry lack of technical speak) from where the two had clearly been bashing each other for a long time.
Also there was a lip formed at the other end that looked to be caused by the driveshaft grinding away at this point.
Nathan got rid of the lipped sections and put the front back together.
I took it for a drive to get it to shake, it will still shake a TINY bit but only after one of those huge speed humps where the car gets all 4 wheels on it (the type outside most schols). This is really no problem as you can simply wait for the rears to be back on the road and then accelerate. By doing this there is no shaking at all.
Hope this helps guys.
(total cost inc new genuine CV boot was only a few hundred - a small price to pay to solve this issue)
I had this problem, and asked my mechanic to look at this post. He found issues with the CVs as you described... problem is now resolved! Thanks very much!
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
